586,082 active members*
3,918 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Best Table Setup to Load Materials
    Oct 2007
    25
    Does any body has seen the table that can be lowered to load steel plates?
    The question is related to a TM3 of 8' by 20' that I will be putting together.
    So what is better, to have a fixed table or one that can be lowered?
    Aug 2007
    264
    I've seen a similar table used to load stacks of material into a shear. If I remember right, the lift device was a hydraulic scissor lift. Might be easier to buy a forklift.
    Mike
    Oct 2007
    25
    But with plates or sheets of material being 20' long, a forklift will not be enough to lift the plates evenly. The material will curve a lot.
    Any other ideas?
    May 2008
    39
    a two hoist crane that would make it easy
    baker
  1. Rotary Table as 4th Axis (setup help)
    By fc911c in forum Mach Mill
    Last Post: 04-03-2009, 04:08 PM
  2. HELP selecting MOTOR size 1 AXIS 8 ft table with load 1000 lbs
    By cjchands in forum Mechanical Calculations/Engineering Design
    Last Post: 08-08-2007, 02:27 AM
  3. Small Hobby Setup/Kit for Inlay Materials?
    By turbo411 in forum DIY CNC Router Table Machines
    Last Post: 01-02-2007, 02:32 AM
  4. Table setup - Axis invert
    By horse in forum Uncategorised CAM Discussion
    Last Post: 02-28-2006, 03:45 PM
  5. Rotary Table Outrigger setup
    By walter in forum Mechanical Calculations/Engineering Design
    Last Post: 11-08-2005, 03:19 AM
