587,070 active members*
3,069 visitors online*
Results 1 to 13 of 13
    Apr 2005
    903
    Garage door height and VF2
    I did some checking and found that the Side Mount Tool Changer on the VF2 is 94".
    My garage door is 94.5" (I can get 95" by removing the trim.) So, I need to figure out how to "slide" the machine into the shop. I know for a fact that the garage door header is non-bearing so notching (if completely necessary) would be an option.
    I was thinking that I could build a dolly of some sort that I could lift the mill a 1/4" or so off the ground. Just enough to make it mobile!
    Are the 2 slots in the front of the mill for a fork lift?
    http://www.haascnc.com/VMC_specs.asp...0#VMCTreeModel
    The HAAS rep didn't know with conviction weather or not the height of the tool changer was my only height concern. Can the other components be removed to clear my door?
    Feb 2007
    205
    You probably could remove the SMTC sheet metal and get another two inches
    Jul 2005
    12177
    Quote Originally Posted by l u k e View Post
    .....I was thinking that I could build a dolly of some sort that I could lift the mill a 1/4" or so off the ground. Just enough to make it mobile!...
    Are you sliding on a firm surface, concrete or black top?
    Lay some strips of 1/4" thick UHMW polyethylene on the floor and just slide the machine along these.
    About the only thing you might need to do is lift the machine up and chamfer the corners of the 'feet' on the machine. You will need this so they do not tend to cut into the plastic.
    These slides and two good Come-Alongs to anchor points drilled into the floor at the back of the garage and you will slide it in as easy as can be.
    EDIT: Also to get a bit more height without notching: If the garage walls are not lined so you can get at the bottom plate just detach this from the foundation and jack the entire wall up an inch or so. You can probably do this with a couple of pole jacks under the door header.
    I am pretty confident both these ideas will work....because I have done both.
    Apr 2005
    903
    I do have concrete inside and out side the shop.
    Jacking up the shop is not possible.
    My first thought was to sit the machine on a 1/2" thick piece of plywood, throw down sand on the concrete and drag it in that way.
    Jan 2008
    92
    Haas has instructions for getting it through doors down to 72" (I think) on the VF2. My door is 84", they are delivering my VF2 on Friday.
    Jul 2005
    12177
    .....My first thought was to sit the machine on a 1/2" thick piece of plywood, throw down sand on the concrete and drag it in that way.
    You will find the UHMW is much more slippy than the sand under plywood.
    Jan 2008
    92
    Not necessary... Talk to your HFO, they have instructions on which parts to remove in order to get each machine through various sized doors.
    Quote Originally Posted by Geof View Post
    Apr 2005
    903
    Quote Originally Posted by jmcglynn View Post
    I did and they offered no such info. All I got was a drawing showing the height of the tool changer.
    Jul 2003
    1220
    If your concrete floor is reasonable smooth you should be able to slide on the concrete.
    22 gauge sheet metal will help.
    I dragged my 9000lb machine centre like this.
    Attached Thumbnails Attached Thumbnails IMAGE0102.JPG.jpg   IMAGE0104.JPG.jpg   IMAGE0106.JPG.jpg
    Apr 2005
    903
    Quote Originally Posted by Kiwi View Post
    If your concrete floor is reasonable smooth you should be able to side on the concrete.
    Now that's tight! Pretty close to what I'm looking at.
    Mar 2007
    10
    I moved mine in with a pallet jack
    Apr 2005
    903
    http://www.haascnc.com/VMC_MODEL_20IN.asp#VMCTreeModel
    Nov 2007
    1702
    Are the 2 slots in the front of the mill for a fork lift?l
    No. IIRC: they are designed to fork from the side. Those holes are so you can get inside the sheetmetal to the leveling feet on the front of the casting.
    Greg
  1. Screw Drive garage door opener
    By Kevin McFarl in forum DIY CNC Router Table Machines
    Last Post: 01-17-2009, 11:34 PM
  2. Did you start your business in your garage?
    By katiebo in forum MetalWork Discussion
    Last Post: 05-31-2008, 07:23 PM
  3. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
  4. Garage Door CNC Gantry Router
    By DougMorency in forum DIY CNC Router Table Machines
    Last Post: 02-20-2006, 08:57 PM
  5. 4020 move, minimum height door???
    By morestuff in forum Fadal
    Last Post: 08-18-2004, 04:50 AM
