586,116 active members*
3,288 visitors online*
Results 1 to 12 of 12
    Nov 2006
    51
    Question VB6,VB.net,VB script,What one???
    hello all,
    I've been using Macro's for programing families of parts but would like to start using Visual basic instead, Is there a specific version of VB I should use for CNC? What one works best?
    Feb 2008
    267
    VB6 is no longer supported.
    You can get VB.NET 2008 Express free and would be a great place to start.
    I'm not 100% on VBScript.
    However, macro for families of parts is still very good.
    One program for many parts makes Rev changes less of an issue.
    Change one program vs changing many.
    Just MHO.
    Good luck.
    Jul 2003
    1220
    I use VB6 and find it great. Never had a problem because its not supported by MS.
    I understand VB.net is much harder to learn.
    Mar 2006
    489
    I wouldn't say .net is harder to learn, just structured differently than vb6. VBScript is more geared for web applications...
    Either will work fine for making gcode output.
    Paul
    Quote Originally Posted by fatal-exception View Post
    If you don't know either, than probably not. But for the occasional VB user, I think .net is definitely harder. Probably due to having to unlearn the VB stuff.
    Nov 2006
    51
    Smile
    I think i'll go with VB .Net then.
    thank you all.
    332
    Quote Originally Posted by hydrospin01 View Post
    thank you all.
    I learned vb.net as a beginner with no previous experience using the express version. Much online help is available. I made an application to control an industrial 6 axis robot with voice commands. It took a while to learn but I was incorporating a lot for a first time project; text parsing, logic, command flow, i/o and the voice interface.
    Jan 2006
    204
    Quote Originally Posted by keithorr View Post
    I am a Block one square one beginner, where would you recommend I look online for Help
    archie =) =) =)
    332
    Quote Originally Posted by jeep534 View Post
    I am a Block one square one beginner, where would you recommend I look on-line for Help
    archie =) =) =)
    same here. I started with the tutorials in vb.net. I add parts to my application in separate projects rather than screw up my main effort. I used the on-line ask a question feature that led to a lot of different examples. After a while I started to see patterns in the coding. I'd also google key words as a lot of clues are outside the msdn scope.
    Learning to parse text files to recalculate axis values was the hardest.
    There are many sample projects available that demonstrate different aspects.
    Jul 2003
    1220
    A simple program called AWK or MAWK or GAWK is excellent for this purpose.
    Apr 2005
    3634
    Free DXF - vectorink.com
    Apr 2005
    80
    I totally agree. I have used VB6 for a long time and have a real hard time getting used to .NET. I also know C and VB script. If you are starting out without knowing VB6 .NET probably wouldn't be bad.
  1. Lookahead script
    By Rikard L in forum Visual Basic
    Last Post: 09-11-2007, 07:28 PM
  2. Lookahead Script
    By Rikard L in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-10-2007, 08:06 PM
  3. Macro/script-can this be done?
    By Splint in forum Rhino 3D
    Last Post: 02-13-2006, 04:50 AM
  4. Backup Script..
    By Rekd in forum Mastercam
    Last Post: 09-11-2003, 03:34 PM
