With that material and tolerances I wouldn't even consider putting them on my L-20's, I'd throw that job on my Nakamura and have all 20k done in two weeks.
As for machining Nylon (any kind) use very sharp edged tools, a lot of coated inserts are not edge honed and you wont get a good finish. I would consider using a plain old HSS tool sharpened on a diamond hone. Use a good size nose radius as well, high feed and cut to size in one pass.
Drill it first with a drill made for plastic (included angle and spiral) and face, turn and part with the same tool. If you put the drill and the tool on the same holder, you don't even have to index. 20 seconds max per part.
Tinmuk
Any problem can be solved by the proper application of heat!
