586,032 active members*
3,010 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Partner VM16 series A stuck in dos
    Mar 2008
    Here's what happened. I sent a file from my computer that was too large for the memory, when it filled the memory, the machine shut down, and the screen went to dos, and said that you need to power down and back up to restart the controller. Did this, and it took forever to boot up. When it did come up, it went directly into dos. Can I delete the program file while in dos to free up memory? Will the software start when I power down/up the machine after doing this? HELP!!!!!!!!!!!!!!! New to milltronics.
    Mar 2006
    370
    if you delete the g-code file from the dos prompt that should not hurt anything.
    use the dir command to see the directories,
    use the cd command to change directory and
    use the del command to delete the file.
    Mar 2008
    19
    generally the directory like below:
    usually the directory like below if you install a hard disk:
    A: \ROM
    B:\RAM\
    C:\PARTS\ (HARD DRIVE)
    D:\ (FLOPPY)
    E:\ (GRAPHICS)
    you could delete the program at the directory of C:\PARTS\
    but the directory different as the different machine, you could find the correcttion directory as single phase said.
    Any question alright? I glad to reply for you!
    Mar 2008
    Thanks, worked great.
    Found the file, deleted, all is well.
  1. Help with Bridgeport Interact Series 1 MK2 Stuck on the Limit Switches
    By mwibbels in forum Bridgeport / Hardinge Mills
    Last Post: 02-05-2009, 09:33 PM
  2. VM16 with CSM 11405-706
    By Radius in forum Milltronics
    Last Post: 03-30-2008, 03:20 AM
  3. Partner 1 Series G- CMOS display type mismatch
    By life3970 in forum Milltronics
    Last Post: 02-01-2008, 04:00 AM
  4. VM16 Info
    By elecbeaver in forum Milltronics
    Last Post: 06-23-2007, 01:34 AM
  5. VM16 CNC shutting down
    Last Post: 05-22-2007, 12:22 AM
