586,389 active members*
2,978 visitors online*
    Dec 2007
    85
    Memory Batteries AM1
    Hello, my controller specifies Alcaline Magnesium Dioxide batteries (AM1) and I have been told that they are just industrial grade alkaline batteries.
    Can someone confirm this or recommend something better.
    The old batteries were quite nasty and leaking acid so they should at least be better for now.
    cheers
    Jun 2004
    42
    TADIRAN part number TL-5242/W 3.6 volts HIGH ENERGY LITHUM BATTERY phone number 1-800-433-5700 or www.alliedelec.com is the dealer I purchased mine from. The Anilam controller that is in my machine had one installed. This battery comes in a case with pig tailed wire that plugged in to the computer board. Oh yes my controller also had the remains of an old battery box that was quite nasty. Someone left the junk in there<grin>
    Have a great day
    Dec 2007
    85
    D Cell
    Hey, thanks for the reply. I should have said that I replaced the batteries with D-cells as they were the same size and voltage.
    I am wondering if D lithium would be better although I don't know if they exist. I will check out your link
    thanks
    Dec 2007
    85
    LInk
    That link showed a panasonic D-cell when I searched for AM1 as a part number for the item.
    I should be ok with the Alcalines that I purchased at the electronics supply but will pick up panasonic replacements if the voltage on them does not hold up.
    thanks
  1. Fanuc 10M Parameters...no batteries
    By spank in forum Fanuc
    Last Post: 03-29-2011, 08:56 AM
  2. Old t1 control lathe and 4 "aa" batteries
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-06-2008, 12:13 AM
  3. DT-Center Batteries ??
    By scott1980 in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2007, 03:21 PM
  4. R2E3 batteries?
    By sharp-shooter in forum Bridgeport / Hardinge Mills
    Last Post: 11-20-2006, 05:02 AM
  5. 88 Memory ?
    By Bear in forum Fadal
    Last Post: 09-01-2006, 12:26 PM
