586,103 active members*
3,859 visitors online*
Results 1 to 7 of 7
    May 2004
    200
    need a bandsaw
    Guys, Im looking or a band saw that like this one at Harbor Fright. My problem is the harbor fright band saw is a 62 inch blade and I can only find bi metal blades that size. I have also been to Sears and Home Depot with no luck.
    Any suggestions
    Tek
    Apr 2004
    439
    may be ?
    http://www.highland-hardware.com/ind...OD&ProdID=1295 costum blades for 30.00
    and
    http://www.toolcenter.com/Lenox/62blades.htm
    never used them just came up on my searchs. so check them out befor sending your money
    Jul 2003
    125
    www.suffolkmachinery.com is another option. Just give them a call and tell them what saw you have and what you're trying to cut and they'll do the rest. In my experience they tend to insist on being helpful.
    Out of curiosity, what are you trying to cut? A jigsaw would be a better option (and less expensive in the blade department). I would not anticipate doing a lot of resawing with this three-wheeler.
    234
    Little Machine Shop has some good blades.
    May 2004
    200
    Quote Originally Posted by Chagrin
    [url]I would not anticipate doing a lot of resawing with this three-wheeler.
    what do you mean??
    I plan to cut up to 3/8" aluminum
    Aug 2003
    79
    If the cuts are straight, just use a table saw with carbide blade. I do it all the time and have cut up to 3/4 inch plate with no problems.
    May 2004
    200
    Most of the cuts will be straight but I need to do round corners
  1. Vertical/Horizontal Bandsaw purchase
    By ChrisJ in forum MetalWork Discussion
    Last Post: 07-21-2007, 02:30 PM
  2. Bandsaw Blade recommendation needed
    By Swami in forum MetalWork Discussion
    Last Post: 03-15-2005, 06:08 PM
  3. need help; bandsaw blade welder
    By SteveD in forum DNC Problems and Solutions
    Last Post: 05-20-2004, 07:55 PM
  4. Bandsaw accuracy?
    By gtslabs in forum MetalWork Discussion
    Last Post: 12-30-2003, 04:26 AM
  5. Can you cut Al. with a wood bandsaw
    By CactusChip in forum MetalWork Discussion
    Last Post: 11-20-2003, 10:45 PM
