Hey guys
First time on the site. Already have learned a few new things..
I do need some help. I have a tm-2 that came from the factory without the 4th axis pre wire. I bought a used brushless 210 rotary table and need it up and running. I beleave I can find a servo amp and cables to make this work.
There are 2 wires i beleave i need. A short wire that feeds info to the amp from a computer board above ,and the wire assembly going out of the amp to power the servo, this wire is attatched to the machine with a female pin connector facing outside. the 210 already has the long wire with the male pin connector on it ready to go.
I am assuming I can get these wires from haas.
My main question is. Do I have to pay to set setup my parameters to accept the new hardwear? Or can these be changed by myself for free? And what parameters will I need to change?
I called the techline and asked, I got some cockey guy on the phone that pretty much told me I need to spend $2100 in new haas parts to make my 210 table work. Then they will tell me how to set my parameters up.
thanks for any help
dave
