586,471 active members*
4,307 visitors online*
    Jan 2007
    93
    analog +/-10V signal gen
    Hi!
    Where can i buy board that generates +/-10Volt signal from step/direstion?
    Like Pixie-P100!
    Mar 2005
    59
    Quote Originally Posted by visky View Post
    Hi!
    Like Pixie-P100!
    www.cnc4pc.com > Speed control board
    Juka
    May 2006
    2420
    Do you want this as a servo drive to connect to an industrial type servo amp ?
    I am doing something similiar, but converting a PWM and Dir drive to +/- 10V (DSPIC).
    It is a work in progress and I am building the standard amp first then adding the +/- 10V
    Here is a schematic for the PWM/Dir to +/- 10V if it helps...
    Russell.
    Attached Files Attached Files
    Jan 2007
    93
    Fine
    But i would like to make it a litle diferent.
    This is a single +/-10 VDC but how to make it diferential, to have two outputs?
    One for 0-10DVD and second -10 - 0 VDC .
    Where should i change this circuit?
    May 2006
    2420
    Do you mean something like this ?
    You will lose 0.6v across the diode and you should use fast recovery diodes.
    Russell.
  1. Rs232 Analog Module
    By elogicca in forum CamSoft Products
    Last Post: 03-16-2008, 12:16 PM
  2. PWM and DIR -> +/-10VDC analog signal
    By visky in forum CNC Machine Related Electronics
    Last Post: 11-21-2007, 09:28 PM
  3. PWM to analog
    By Drew in forum Machines running Mach Software
    Last Post: 10-10-2007, 04:40 AM
  4. analog signal from serial port
    By roni21702 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-09-2007, 05:06 PM
  5. Getting analog signal from pc
    By roni21702 in forum Computers / Desktops / Networking
    Last Post: 06-15-2006, 07:34 PM
