586,058 active members*
3,534 visitors online*
Results 1 to 10 of 10
    Nov 2006
    925
    Mazak M2 batteries.
    Anyone got an alternative supplier/part number for the Saft GB150H-3F batteries used on the M2 boards.They are 150 mah and look like three button cells side by side with fixing lugs at the ends.
    Mark.
    Sep 2006
    251
    Battery supplier
    Quote Originally Posted by gridley51 View Post
    Mark.
    Mark,
    Try batterywholesale.com. they are worldwide and can help you with this.
    Just a good ol' boy, never meanin' no harm.
    Joe
    Apr 2007
    29
    Go to the Interstate battery web site, they have the same batteries for $11.00 as to the $86.00 you will spend at the OEM, BUT I HAVE TO WARN YOU, if you are putting these batteries in a component that is under warranty, the warranty will be VOID.
    Htech
    Oct 2005
    420
    Mark,
    Took me a while to go back through my notes but the NEW part number for the M2 batteries looks like D50MA001020. Not sure on your machine as I think you have an updated M2 control, but my machine required 2 of these. 1 holds the memory for parameters and 1 holds programs (EIA/Mazatrol).
    Hope this helps,
    Nate
    Nov 2006
    925
    Thanks for the replies guys.I had forgot you had replaced batteries Nate or would have emailed you.Will also have a look at the Interstate site.
    Mark.
    Nov 2006
    925
    Interstate can do these batteries on a thirty day delivery but do not ship outwith North America.Armed with Mitsubishi`s part number I called up Mits Automation UK.Got passed to Mits Germany.Refuse to supply them,told me I have to buy them from Mazak.When asked why,was told "because that is the rules".
    Most infuriating.
    Mark.
    Jun 2008
    Felectric
    Hi I'm a newbe here.
    Can anyone tell me the location of the parameter memory battery(s) for a
    Mazatrol T32-2 Lathe?
    Jun 2007
    43
    Mar 2008
    175
    Felectric- I have a T32B control and it has one located in the bottom left hand side of the NC unit. There will be a thin steel cover mounted vertically labeled MC063, remove the cover and the battery is mounted to the card.
    If you need a replacement battery, any battery shop can build you one from the specs off the old battery for about 10 bucks. Just check the battery height to insure it will fit in the slot once mounted on the card.
    My local Interstate battery shop built a replacement from 3- 1.2V 200m/amp Ni-HM stock batteries while I had lunch.
    Jun 2007
    43
    There is an error in my last post here, it should read, www.mdsbattery.co.uk not mbsbattery as I wrote
    gem
  1. Fanuc 10M Parameters...no batteries
    By spank in forum Fanuc
    Last Post: 03-29-2011, 08:56 AM
  2. Memory Batteries AM1
    By greenchair in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2008, 07:42 PM
  3. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
  4. DT-Center Batteries ??
    By scott1980 in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2007, 03:21 PM
  5. R2E3 batteries?
    By sharp-shooter in forum Bridgeport / Hardinge Mills
    Last Post: 11-20-2006, 05:02 AM
