586,379 active members*
3,696 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Self leveling Epoxy for making linear rail mounting surfaces
Page 1 of 2 12
Results 1 to 20 of 38
    Sep 2006
    177
    I've been looking for an easy way to turn a non-flat steel surface (error~.020" over 56" length) into something suitable for linear rail mounting. My idea is to use a low viscosity epoxy and pour it into a mode built on the steel plate to a depth of about 1/8". I thought i would post this to see what the general consensus is here.
    One of the major factors will be the viscosity of the unhardened epoxy mixture. Several companies sell some low viscosity stuff: MAS epoxy looks to be the most promising. Their standard "Mas resin" with a slow hardener has a viscosity of 550-650cst and a work time around 23 min). They also have lower viscosity stuff around 120cst but the minimum quantity is somehting like 4gal. I'm going to give the Mas standard resin a test (mounted on a granite surface plate to accuractly measure the resulting surface).
    Two options (from West systems epoxy) for lower the mix viscosity are:
    1. Heating the components before mixing (drawback here is the decreased set time)
    2. Adding several percent solvent (several were listed). this has several major drawback like lower epoxy strength and increased shrinkage
    Jul 2003
    586
    look at this thread almost everything is discussed hear on the topic. it is long but bountiful.
    http://www.cnczone.com/forums/showthread.php?t=30155
    Apr 2007
    1955
    Your idea is a great one. The epoxy properties to make it work are slightly more complex than you might think, but life is good. Here is a link to a company that makes exactly what you need. They do this for a living, so it is a tried and tested solution. I have discussed this application with them and the ability of their epoxy to go "flat" is amazing.
    http://www.precisionepoxy.com/
    Approx $ 50 / gallon for each component.
    Hi
    Have a read through this thread I know Hayden used epoxy to mount his rails on.
    http://www.cnczone.com/forums/showthread.php?t=30751
    Andy
    Nov 2007
    140
    Moglice
    Moglice.com
    Dec 2007
    33
    epoxies
    look into system3.com.
    Mar 2004
    1661
    I've done it too, works like a charm.
    Mar 2008
    5
    bondo
    I f the idea is to fill in small gaps why not use bondo? the key as I see it is to find a reference edge to use to show what needs filling. You might use a length of aluminum angle. Lay it down on the surface and shine a light under it. Use the bondo to fill in the gaps an sand it smooth with a hard flat sanding block. Just a thought.
    Sep 2006
    177
    ha...thanks for all the replys
    Sep 2006
    177
    Svenakela, do you remember what grade/type of epoxy you used. Also, what size of area and thickness did you make.
    Jan 2006
    2985
    Quote Originally Posted by harryn View Post
    They say its perfectly flat but its actually only as good as the radius of the earth allows. The epoxy will actually be arched at the radius of the earth. Think of it like a smaller version of the "flat" ocean, which wraps itself around the earth.
    The error doesn't matter for this application but it is interesting to ponder.
    Matt
    Sep 2003
    1470
    Smile
    Quote Originally Posted by keebler303 View Post
    Matt
    OK you math wizards If the rail is 4 feet long, how much will it be arched in the center? (Height on center compared to the ends)
    Quote Originally Posted by Mr.Chips View Post
    Not sure, but the radius of the arc is about 251,064,000 inches (3962 miles).
    AutoCAD won't let me draw it, because it's too straight.
    Jul 2006
    1256
    Mack,
    The curvature of the earth is .000126/mile or 8"/mile.
    The right epoxy is table top epoxy.Regular laminating epoxy may blush.Rather than go on about it,use the correct material.TT epoxy for $20/2quarts.
    http://www.uscomposites.com/kk121.html
    Check my avatar.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Mar 2004
    1661
    Quote Originally Posted by mackeym View Post
    NM 258, Swedish high quality brand. It's not even 1 mm at the thickest place. I layed the gantry horizontal on a polished stone surface, aligned it in 90 degrees, made a small barrier around the beams with tape and the poored the resin. The epoxy is post treated with heat and now it's really hard and very straight.
    Sep 2006
    177
    ha, that's right; there will be some curvature. Based on the equation of a circle, the amount of error or vertical distance (from the center to either end of the epoxy plate) in inches is:
    Vertical Error=(6367000-(6367000^2-EpoxyLength^2/4)^(0.5))
    The input "EpoxyLength" must be inputted in units of meter
    For a 4ft length epoxy plate, error is 1.17x10-6 in or about 3 nm
    Which is essentially 0 for our purposes. The surface tension will also cause additional bowing in the same direction. This might or might not have a much larger affect than the curvature of the earth.
    Sep 2006
    177
    Wait, there's an error in that equation, i'll post the right one a little later
    Sep 2006
    177
    Nevermind, that equation was right. The .000126/mile or 8"/mile number is NOT the distance one would be interested in for surface plate flatness. It is right, but not in terms of surface plate error. I attached a picture showing the difference if anyone is interested.
    Jan 2006
    738
    I think you will be about 0.000001147" high in the center.
    Steve
    Jul 2006
    1256
    OK,
    I guess the curvature of the earth is not a concern.Svenakela's method of the tape is the best way.Daming or a mold is difficult as epoxy will seep through the tinyist hole.On a long cure,epoxy may penetrate masking tape.Gaffers tape works better.
    .003 is easy to get,possibly.001 with lowering the viscosity by applied heat.If you need better,lapping with a granite surface plate is in order.
    Larry
Page 1 of 2 12
  1. Self leveling epoxy resin-wear characteristics?
    By Splint in forum Uncategorised MetalWorking Machines
    Last Post: 07-23-2007, 02:11 PM
  2. thoughts needed: accuracy frame/rail leveling, etc
    By blau_schuh in forum DIY CNC Router Table Machines
    Last Post: 07-04-2007, 12:45 AM
  3. Making you own DYI rail for linear blocks
    By java77man in forum Linear and Rotary Motion
    Last Post: 06-26-2007, 04:00 AM
  4. making surfaces from lines
    By KevinP123 in forum OneCNC
    Last Post: 10-11-2006, 12:21 AM
  5. question about thk rail mounting
    By mwp in forum DIY CNC Router Table Machines
    Last Post: 03-10-2005, 07:10 AM
