586,266 active members*
5,019 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > using a saw blade?
    Nov 2007
    28
    using a saw blade?
    i have been lead to be belive that only a router type cutters can be used and that interpolating 3 or axis with a sawblade in not possable as the curve of the blade can not be accounted for
    is there a way of using a sawblade to grind away the profile when the shape requires the z to rise and fall over the profile as the cutter moves along the as the Y
    many thanks mark
    Jun 2006
    3063
    It seems to me that you could model a saw blade as a very wide diameter end mill with a very short height. For clearance calcs, you might be able to model the arbor as a very funky looking holder.
    Mike
    Nov 2007
    28
    Talking
    like your thoughts may try this soon the blade is over 1000 mm so i hope that there are max sizes to contend with
    I saw some pics of stone carving, and they did the roughing with a saw.
    http://www.digitalstoneproject.org/index.html
    Not sure what software would let you do that, though.
  1. Milling heli rotor blade
    By daddyhobby in forum WoodWorking Topics
    Last Post: 04-30-2008, 07:34 AM
  2. 5 Blade Fan,
    By CharlieM in forum G-Code Programing
    Last Post: 02-13-2008, 11:52 PM
  3. Building Fabric Cutter with blade
    By handrade in forum Community Club House
    Last Post: 08-29-2005, 11:30 PM
  4. need help; bandsaw blade welder
    By SteveD in forum DNC Problems and Solutions
    Last Post: 05-20-2004, 07:55 PM
