586,599 active members*
3,580 visitors online*
    Nov 2004
    239
    4 Position Rotary Switch
    I have a MIG welder that was equipped with a 4 position rotary switch. The switch was locked up so I decided to take it apart to see what the problem could be. In the disassembly phase the switch came apart suddenly and I didn't have the opportunity to see how it was put together. Is there anyone with a good working knowledge of 4 position rotary switches?
    I know this isn't electronic but this is the closest forum I found.
    I've posted on 2 welding forums but the interest seems to be in telling me where I went wrong.
    24223
    Quote Originally Posted by Shanghyd View Post
    Unfortunately there is no standard for '4 Position Rotary Switches'. It can be an off the shelf configuration, which there are many options, or custom ordered by the equipment manuf.
    An idea of what the function is for the switch or a schematic, is required, which I assume you do not have?
    If it is a well know unit, you should be able to get the schematic.
    Al.
    Albert E.
    Nov 2004
    239
    I have a thread with pictures at the welding forum.
    http://weldingweb.com/showthread.php?t=20529
    It's a switch for a mig welder.
    Jul 2003
    1754
    I would think the schematic would give you the switching sequence. From that you should be able to put it back together.
    Nov 2004
    239
    I ordered a new switch from a supplier. Probably best anyway.
  1. Mazak Rotary Turret Switch reBuild
    By Al_The_Man in forum News Announcements
    Last Post: 04-11-2007, 04:21 PM
  2. Rotary Position device... Belt VS Gearhead
    By 54Oval in forum Mechanical Calculations/Engineering Design
    Last Post: 03-09-2007, 06:49 AM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Home switch position
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 12-17-2004, 01:00 AM
