586,119 active members*
3,466 visitors online*
Page 1 of 2 12
Results 1 to 20 of 30
    Dec 2007
    98
    Question RFQ- Small job on a front and rear panel
    I need to get some panels made for a chassis for some electrical equipment I'm building. It's a DAC that I'm working on and I just need a front and rear panel. I'd like them made in 1/2" aluminum anodized black. It would have a recessed hole and a through hole and then some engraving. I can draw up the solidworks files and send them or what not I'm just wondering how much someone her might charge me to run them and for materials and what not? The engravings wouldn't have a fill would just be the bare aluminum underneath and the panels would be 12"x3" and 12.5"x3.5" 1 of each. Anything else you need to know I'm sure I can answer.
    Dec 2007
    98
    In case anyone was wondering what it would entitle, here is the front panel. Right this minute just wondering how much it would cost not sure when I can buy them for sure but would be in the next month or so. There are a few engravings missing because I have to figure out exactly where they should be. As for the rear panel it will basically be .5" thick 12"x3" and have several holes and a few engravings. Hopefully this is enough info to get a quote?
    Attached Files Attached Files
    Apr 2003
    1873
    Bad file Doug.
    Ken
    Jan 2004
    105
    Quote Originally Posted by Ken_Shea View Post
    Bad file Doug.
    Ken
    Rhino3D dug it.
    Here's a dxf.
    Apr 2003
    1873
    Rhino3D dug it.
    Hmmmmm, that's interesting !
    All I get is a File read error, when it did load there was no geometry or solids.
    Dec 2007
    98
    Sorry... I'm not sure if I did it wrong? I have the rear panel now as well but its the same sort of format. I'm not so great with solidworks been learning though.
    Oh and if anodizing adds that much money just skip it and let me know just for brushed and the engraves would then be filled black I suppose? Would this save much. Sorry I'm cheap
    Apr 2003
    1873
    No sure what is going on Doug, still no data when importing.
    Must be on my end as Monte seemed to have imported it ok.
    Cheap can work with wine and women but not usually with one off machining
    Dec 2007
    98
    Well I'll say I'm cheap but reasonable
    Jan 2004
    105
    Shoulda' said Rhino3D v4.0, if that makes a difference.
    Monte
    Apr 2003
    1873
    Think I will send that file off to support and see if they may find a reason for it not importing.
    With your permission Doug?
    Dec 2007
    98
    Ummm... I guess? it's probably something I'm doing though I haven't used Solidworks much its my friends copy he doesn't use it and let me try it out.
    Apr 2006
    100
    Ken What are you using for software? sometimes if solidworks is a newer version than what you are using for Cam software it becomes a problem. I know this happens between Gibbs cam and solidworks. Solidworks releases a new version and Gibbs cam can take a few weeks to catch up to the new features in solidworks. This could be the issue here?
    Mike
    [email protected]
    www.hessemachine.com
    Apr 2006
    100
    Doug maybe save it as an Iges file. this usually has little or no problems in almost all softwares no matter what revision it is.
    What version of solidworks are you using? 2008 will probably cause a few problems with some softwares, it is geared more towards the Vista operating system, and has many changes from the previous version.
    Mike
    [email protected]
    Apr 2003
    1873
    Mike,
    I am using OneCNC XR3 Mill Pro,
    This is the first time I have ever encountered any problem importing .sldprt files, they have always imported perfectly with out fail.
    XR3 is the newest version that is why I though it may be of value to send it to support and see if it is a software, file or machine related problem or a Dougie085 problem
    Lots of stuff to cause a glitch, that's for sure.
    Ken
    Dec 2007
    98
    Let me try the Iges.
    Dec 2007
    98
    Try this.
    Apr 2006
    100
    Thanks Ken I was just curious, I would be interested to see what version of solidworks doug is using? I know solidworks changes ther file formats because it can really be an issue with gibbs cam, and they are supposed to be kind of partners.
    Mike
    [email protected]
    Dec 2007
    98
    2008 SP0.0 I need to update it to SP1....
    Apr 2006
    100
    Doug SP 3.1 is actually out as of last week or the week before. I think you can go right to that. I'm not sure what the difference is.
    Mike
    [email protected]
    Apr 2003
    1873
    That works fine Doug.
    One issue on the part will be the square corners in the rectangular hole, can you have any radius here ?
    If not, laser, water jet or EDM, all of these are not going to be uh...... reasonable
    Out side of that is is a very straight forward job.
Page 1 of 2 12
  1. am i allowed to ask this?
    By StinkFish in forum CNC Tooling
    Last Post: 11-23-2007, 11:46 PM
  2. No laughing allowed...
    By Dave's_Not_Here in forum CNC Machine Related Electronics
    Last Post: 06-08-2005, 07:16 AM
  3. Just wondering
    By les turner in forum DIY CNC Router Table Machines
    Last Post: 03-02-2005, 03:50 AM
  4. Just Wondering...
    By High Seas in forum Hobby Discussion
    Last Post: 10-25-2004, 11:25 PM
