I'm not sure if it's a simple software problem or a factory setting, but the rapid traverse is WAY TOO SLOW when a program is running and G00 is invoked.
When jogging in rapid, everything flies around at a good speed, but when a program is running (even a simple test to move it around) it's the slowest thing ever, really hurting cut times.
I've been digging through the manuals (which have you jump around between to get an answer) and can only come up with the following....
Under PARAMETERS, #6219 needs to be set to 1 (currently at 0) in order to change the Rapid Traverse rates parameters.
In order to change #6219 to 1, you have to move a switch on the mainboard to 1 from 0. Either I'm doing something wrong, or this isn't the correct step.
I believe that after setting #6219 to 1, you should be able to cursor to, and change the #6280 and #6281 parameters (Z and X rapid traverse settings)
Problem is that I can't even get #6219 to change!
I hope I'm doing this wrong and there's some simple fix, which is why I'm reaching out to you all. Any information and advice would be greatly appreciated!
Thanks in advance.
