586,102 active members*
3,180 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Spindle won't start!
    Dec 2006
    21
    Hello,
    The spindle on my VMC20 won't start. It stopped in the middle of a program today, and won't restart. I shut everything down and restarted. In MDI it will change from hi to low, but when I try M3 the alarm says "Spindle Motor Overload". Any ideas would be most appreciated. You guys have saved my butt on more than one occasion!
    Gamila
    Apr 2008
    6
    Gamila,
    My guess is your spindle encoder went out. Same thing happened to my 4020. When I M3'ed the spindle just turned at a very slow rpm no matter what I plugged in for rpm. Do you get a C axis fault???
    Good Luck getting back to making chips,
    Gitman
    Dec 2006
    21
    Hello Gitman,
    No C axis fault. The spindle won't move on it's own at all. I get the overload fault and then an emergency stop fault.
    Gamila
  1. spindle don't start in interact 412
    By PRIOR666 in forum Bridgeport / Hardinge Mills
    Last Post: 01-17-2008, 11:37 PM
  2. Sometimes spindle won't start, and ...
    By david_geng in forum Syil Products
    Last Post: 09-01-2007, 01:34 AM
  3. Spindle will not start:HELP
    By raps in forum Fadal
    Last Post: 02-28-2007, 09:32 PM
  4. Help - Spindle Will Not Start from NC Control
    By CSE in forum Bridgeport / Hardinge Mills
    Last Post: 05-24-2006, 05:56 PM
  5. Spindle Start Time out
    By JonLed in forum Fanuc
    Last Post: 03-17-2006, 07:00 AM
