586,036 active members*
3,626 visitors online*
Page 11 of 32 91011121321
Results 201 to 220 of 638
  1. #201
    Jan 2006
    81
    I am going to ask one more time to see if I get any responce. I have tried to reinstall the Blue Screen and it did not work. Here is a shot of what I get. Something is wrong with the probing section of the screen. Mach 3 2.56. Any help would be appreciated. Thank you, James:drowning:.
  2. #202
    Aug 2005
    578
    What is your screen resolution? Try setting the screen to 1024 x 768.
    Bob
  3. #203
    Dec 2008
    62
    Quote Originally Posted by James Marshall View Post
    that is Strange James.....Wish I could help, when you say you reinstalled it did you reinstall the bitmaps too....make sure to delete the 1st ones
    Taig Owners Club.......
    Google Search. Taig Owners Club
  4. #204
    Jan 2006
    81
    OK! I am a moron!!! Some how I did not get the set file and did not under stand the directions. I am pleased to say that the screen is now in proper opperation!! I will try funtionality later on. Thank you all.
  5. #205
    Dec 2008
    62
    Glad to see you got it......Neat Function to have
  6. #206
    Nov 2008
    16
    C10 BOB has pulled-down inputs?
    My C10 BOB's input pins are already pulled low 4.7k resistors.
    So the Touch Test LED is always on.
    How can I get around this problem?
    Thanks for the great post.
  7. #207
    Feb 2007
    4553
    Smile
    Hlombard,
    Attach a 4.7K resistor between +5 volts and the input terminal you would like to use for the touch probe, that will push it high.
    Jeff...
  8. #208
    Dec 2004
    1137
    Quote Originally Posted by jalessi View Post
    Hlombard,
    Jeff...
    It will pull it high but only to 2.5V. Better to use a 470 ohm resistor for a 4.5V voltage on the input. Then connect one side of the probe to ground and the other to the input. When they touch, the input is shorted to ground (0V) and thus the active low triggers in Mach.
    Jay
  9. #209
    May 2006
    1469
    If it were my BoB I would go one better and remove the on board pulldown. Then put a 4.7k pullup on it
    Not expecting you to do that but it is what I would do.
    Greg
  10. #210
    Feb 2007
    4553
    Greg's suggestion about removing the existing resistor cant hurt.
    We have setup several dozen C10 boards for the touch probe just adding the 4.7K between the input and +5 volts and all have worked flawlessly.
    Jeff...
  11. #211
    May 2006
    1469
    Arturo Duncan, the CNC4PC designer has recommended using a 1k resistor to pull the input high.
    4.7k sounds too high to me. However I have neither a circuit diagram or a C10 board here to check.
    As I said though, I would alter the board if it were mine.
    Greg
  12. #212
    Nov 2008
    16
    CNC4PC C10 BOB - Pull-up resistor
    Thanks for the help.
    I found the solution in the manual to the BOB on their website - very well done! Take a look their if you need help.
    They suggest a 2.2k resistor.
    I also realized that my machine was not plugged into the power outlet - so it wasn't grounded ! Stupido !!
  13. #213
    Feb 2007
    4553
    Smile
    Sorry I provided incorrect information.
    Jeff...
  14. #214
    Feb 2005
    32
    hoss2006.
    Is it possible that you can share your screen with all the scripts for us ?
    I am very interested in your features to probe edge and holes.
    Best regards:
    Per
  15. #215
    Jun 2007
    54
    Mach3 Blue Screenset for Mills
    It looks like Artsoft did some reorganizing of their web site so the link to the Blue Screenset has changed. You can now download it from here http://www.artsoftcontrols.com/scree...Blue_setup.zip
    The modifications to the screen set are here http://www.cnczone.com/forums/attach...2&d=1207685850
    Refer back to post #1 for instructions for installing and using the software.
    -Ernie
  16. #216
    Sep 2003
    13
    HI to all
    I have installed the screensets ans sometimes it work just fine, on some occasions when i press the z-zero the spindel moves away (upwards) from the touchplate, why would that happen. when i reset Mach3 z-zero zero`s in the correct direction.
    Regards
  17. #217
    Dec 2007
    101
    Anybody using this also using spindle control? I would like to use the Blue Screenset but I need the spindle control section also.
  18. #218
    Jan 2007
    219
    I created a version of the Silver/Steel screen set with spindle control for my mill.
    www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
  19. #219
    Dec 2007
    101
    Quote Originally Posted by Adamj12b View Post
    Care to share your screenset? I don't have a clue as to how to go about modifying one.
  20. #220
    Jan 2007
    219
    I would love to share. Here you go: http://www.adambrunette.com/Silver_Screen.zip
    It took a few hours copying the buttons from the blue version to the silver and making it look right, But I think it was worth it. You will need to edit the scripts for the buttons to increase the federates. I've slowed them way down for use on my mill. Enjoy.
    -Adam
  1. can you use a probe and mach3 to auto probe a part?
    By skyguynca in forum Uncategorised WoodWorking Machines
    Last Post: 11-28-2013, 01:21 AM
  2. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  3. Need probe macro for M&H Infared Probe 25.41-HDR
    By nikolaiownz in forum Fanuc
    Last Post: 02-11-2012, 03:10 AM
  4. need help with modification
    By ironofeden in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-23-2011, 06:21 PM
  5. Super Probe 17 Functions in one probe
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:46 PM
