586,728 active members*
3,311 visitors online*
Results 1 to 8 of 8
    Aug 2007
    215
    running steppers slowly
    I have an application where I don't need fine resolution. Having done my sums it appears I'm going to be running my (200steps/rev) motors in the range 0 to 2 revs/sec so 0-400 fsps.
    I understand how torque is inversly proportional to speed, but looking at the torque curves I notice that they only start at around 500 fsps - is there anything "funny" I should be aware of going on at the front of the curve i.e. when running motors slowly?
    If it makes any odds I'll be using microstepping drivers.
    Ian
    Yes, there is something "funny" going on. The speed-torque curve shows from 500 full-steps and higher because there are severe resonance notches (down to zero torque) in the curve from 0 RPM to 500 RPM. Otherwise torque is constant from 0 RPM up to several hundred RPM past which it drops inversely with speed. Low speeds require microstepping to get resonance-free operation and full low-speed torque.
    Mariss
    Aug 2007
    215
    Thanks Mariss - So not a problem if I use quality microstepping drives? - got any recommendations?
    Whilst you're around... Could I ask you to take a look at my last post in " I thought I knew - now I'm not so sure..." please - it's about a paragraph in the stepper guide on the gecko site.
    Ian
    Please send a link to it.
    Mariss
    Aug 2007
    215
    Aug 2007
    215
    So... The torque curves for my motor show torque starting at 500fsps to be around the 2.5Nm (354 in oz) mark. Given I'll be using a quality microstepping driver can I assume the following?
    There is absolutely no point in doing "the norm" of using a Voltage several times the rated voltage. Because I'm never going to get to the speed where torque drops inversly with current.
    i.e. I should use the rated voltage of my motor.
    This sounds too easy (for once)
    Comments appreciated.
    Ian
    EDIT: Ah but of course at least one quality driver says the Voltage must be at least 4 times the rated Voltage - Other comments still appreciated though. Thanks.
    I believe that if you try to run the motor at it's rated voltage, the torque will drop off immediately as soon as it starts to turn.
    Also the driver will have a minimum voltage that will be at lest twice the rated voltage of the motor.
    Below this voltage and the driver will not start.
    Quote Originally Posted by stirling View Post
    Ian
    Zapp Automation Ltd
    www.slidesandballscrews.com
  1. 2.3v 3A/Phase steppers running at 35v, what amperage?
    By guru_florida in forum Stepper Motors / Drives
    Last Post: 03-05-2008, 05:27 PM
  2. Getting my V2XT started (very slowly)
    By LandCruiserLuke in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2008, 10:38 PM
  3. Coolant leaking slowly on back of VF3
    By Rocko1 in forum Haas Mills
    Last Post: 12-07-2007, 12:38 AM
  4. running high Amp steppers question.
    By Semisentient in forum Xylotex
    Last Post: 04-21-2006, 11:59 PM
  5. Steppers running Hot?
    By drakesis in forum Stepper Motors / Drives
    Last Post: 07-06-2005, 03:25 AM
