586,106 active members*
3,166 visitors online*
    Jan 2006
    7
    RFQ - small knurled 'caps' for M2 SHCS
    Hi folks,
    I am looking for someone who can produce a bunch (~50-200) knurled 'caps' into which the head of a SHCS socket head cap screwswill then be pressed.
    The caps will allow a user to finger-tighten the M2 SHCS.
    The outer diameter of the 'cap' will be approx 0.25".
    The hole into which the SHCS screw will be pressed will preferably be a 'blind' hole. The OD of the 'cap' will be knurled for finger-grip with a small bevel on OD of both ends of the 'cap'.
    Unfortunately, I need an M2 screw.... It appears that Misumi already has a product that would work if I was using an M3 screw!. I know at least one company produces caps like this, but they don't make them for M2 SHCS.
    The material could be almost any steel, although some sort of stainless would be preferred so they don't get 'rusty' from use/exposure to fingers (these will not be outside).
    Thank you &
    Best regards,
    Chris (nine one six) 295-four-one-nine-four - Pacific time
    Nov 2005
    274
    Do you have a print or would you like me to include the disign and supply of the part print in the quote?
    Bluesman
    Oct 2004
    39
    PM sent
    PM with quote sent.
    Philip Confalone
    Machining Concepts
  1. caps-m?
    By gravy in forum Mori Seiki Mills
    Last Post: 03-02-2008, 01:12 PM
  2. CAPS-M questions
    By davek in forum Fanuc
    Last Post: 02-17-2008, 01:51 PM
  3. RPC Caps question
    By choppersprocket in forum Phase Converters
    Last Post: 12-13-2006, 12:24 AM
  4. CAPS information
    By Kaymen in forum G-Code Programing
    Last Post: 08-22-2006, 07:17 AM
  5. Have 3 caps, which one to use?
    By juxtoposed in forum CNC Machine Related Electronics
    Last Post: 04-21-2005, 06:43 PM
