586,119 active members*
3,586 visitors online*
    May 2007
    Adding a slaved X axis
    Hi all,
    I've built a gantry router which is up and running and i want to improve it by adding another ballscrew and motor etc. slaved to the existing x axis.
    The problem i've got is that the existing x axis (from ebay ) seems to be an odd size ( 18x8 ) and i cant find the equivalent new.
    Can my new axis be a different diameter and pitch and still be slaved to the existing one ?
    I almost dont want a reply as i suspect it will be bad news !
    Cheers,
    Nick
    No, the two axis need to be identical, with identical settings.
    May 2007
    Thanks Gerry,
    I'll have to buy two new ones then.
    Cheers
    Nick
    Sep 2007
    200
    on the up side you'll have a spare=)
    Sep 2007
    200
    i know you may not like this but you could swap out the thread for a chain or pully.
    with two chains or pully, one on either side.
    i've heard they are an improvement.
  1. adding 4th axis with ez board
    By me2cyclops in forum Hobbycnc (Products)
    Last Post: 03-28-2008, 04:29 AM
  2. adding a 4th axis?
    By airbrush in forum Uncategorised WoodWorking Machines
    Last Post: 10-12-2007, 11:00 PM
  3. What do I need to run 4 axis (1 axis slaved)
    By Goose80 in forum Gecko Drives
    Last Post: 12-14-2006, 05:29 PM
  4. adding 4th&5th axis
    By cnc prog in forum Daewoo/Doosan
    Last Post: 09-25-2006, 10:26 AM
  5. Adding A 4th Axis
    By helix77 in forum EdgeCam
    Last Post: 04-13-2006, 08:36 PM
