Just curious but what would you say is a resonable time to machine this part in?
Forgot to mention, just the inner profile, drilling the 4 holes, also tapping them.
Material? Tolerances?
Suppose that would help Aluminum 6061, Tolerance is 0.025mm on the 5mm high walls, other than that not very important, BUT I do get a nice mirror finish on the walls so yeah you can push it but of course the finish must not suffer too much.
I am cutting it with 2 Flute Alu-Cut cutters @ 10000rpm(max of the machine) and am running 1:30 flat per part cycle time, would like to know how close I am to optimum with the 2 flute cutters, when I wear them out I'll move over to 3 flutes and should cut 20 seconds or so, but my supplier didn't have any.
Roughing with 8mm, finishing with 4mm.
Regards,
Jonathan.
Sample attached...
1:30 sounds like you're pretty close to optimum. I took your .xt file and put some toolpath to it in MasterCam. I got a cycle time of 1:50 without really looking too deeply. With some tweeking it could get somewhat better but sounds like you're on target.
Cool thanks for taking the time, very good to know.
Regards,
Jonathan.
