Today i when to hook up my limit switches trought the parallel port in the back of my logitrol cnc controller.
And i set my port and pins to 10 and 13 in the mach 3 config .for x and -x and set it for active high. so i conected all connection from the limit switches to the parallel port in the back of my controller and got nothing..The volt meter only shows only # 9 pin having my 5 v power the rest show zero even when the ports where selected in mach 3 to be active high meaning it is drawing 5 v to that pin .And i cant get 5v to be present on # 10 11 12 13 .Could there be something in Mach 3 that is inabling that pin to be active or could my controller 25 pin be messed up. It is kinda weird cause everything else works..Got any ideas what it could be???? Thanks
