586,077 active members*
3,997 visitors online*
    Dec 2005
    439
    Alarm 971 Fail to Load
    I just started my machine up 10mins ago and got
    The on board device computer failed to load network drivers
    Help!
    I have no idea what to do, I can't use my disk drive USB drive or hard drive
    I'm not lazy..., I'm efficient!
    HAAS GR-408
    Dec 2005
    439
    So i figured out the problem. My machine was cold.. after running my total machine warm up cycle twice it all magically worked
    HAAS GR-408
    Nov 2009
    4
    FAIL TO LOAD ALARM ON VF4D HASS VMC
    Hallo,
    i come across alarm of Fail to load on my VF4D VMC machine, Please suggest what may be the problem
    Keshav
    Oct 2009
    192
    It sounds like a software problem to me. What software version do you have? The software version can be found when machine is first turned on. will probably start with a 13, 14, 15, 16.
    Also - do you have ethernet option?
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Testing encoders? When/Why do they fail?
    By fergusda in forum DNC Problems and Solutions
    Last Post: 02-20-2016, 01:44 PM
  3. Replies: 6
    Last Post: 04-29-2011, 11:20 PM
  4. Lube Fail
    By CC714 in forum Fanuc
    Last Post: 01-24-2008, 05:39 PM
  5. V2XT startup fail error-1
    By photoron2 in forum Bridgeport / Hardinge Mills
    Last Post: 10-05-2006, 05:21 PM
