I have a very general question about Mastercam X2. How do you go about creating tools paths from a solid model? The parts in question will be machined on a 3-axis VMC, so it should be fairly straight forward job.
I am using Solidworks to create the solid models which I saved as a parasolid. I then open the files in Mastercam and go from there. The problem is this is litterally my first day using Mastercam and would love to hear any tips, shortcuts or advice you may have.
I have plenty of references to use, tutorial videos and books, but this is a job that needs to be finished as soon as possible. If this can't happen or is unrealistic we will look for someone to convert the files to code for us and I will work on learning Mastercam on a job that is not such a rush. (I work for a shop that is new to CNC and we are working on limited man power and a tight budget).
As for my CNC backround I have used only the 3-axis VMC mentioned earlier and have only generated code long hand up to this point using Quick Link.
If you have a question that would help you better understand my position or goal please ask. Thanks for any tips you can suggest, Mike
