586,345 active members*
3,139 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Hoss 16 Tool Automatic Tool Changer
Page 1 of 16 12311
Results 1 to 20 of 317
    Decided to get a new thread rolling for the new ATC that I started working on last week.
    The old ATC thread was getting a bit long and it's hard to wade thru all the info.
    This tool changer will, as you've guessed, have 16 tools using the same holders
    as the last one, my versions or the Tormach tool holders.
    It should be compatible with any mill, X2 or larger, that can use a power drawbar
    to open/close a collet.
    The X2 may need to be bolted down to keep from tipping over.
    Unlike the last simple ATC, this toolrack won't be attached to the x,y table at all.
    It doesn't matter which side the rack is mounted to though I'm putting mine
    on the right side since there is more room in the flood coolant enclosure over there.
    I've already edited the code in the M6Start macro from Mach 3 to get everything
    moving just like I want. Tests show it working great.
    Thought of one more thing today, going to add some code to activate/deactivate a solenoid
    to open/close a door to keep chips out.
    Tool changes should be a bit quicker than the last one too.
    There is much less Z axis travel for this one and my Z is the slowest axis.
    Probably won't be much updates for a little while.
    I've started milling the simpler parts by hand (glad I have dual shaft steppers with crank handles)
    but I'll need the CNC back up and running for the complex pieces and I still have a lot of work
    to do on the new mill console.
    The total cost is ballparked around $300 since I already have the Power Drawbar, C6 and C10 boards
    and Tool holders.
    Enough yaking, I have wiring to do, Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Feb 2007
    4553
    Power Draw Bar?
    Hoss,
    Your power draw bar is super kewl!
    I reviewed your plans and wanted to know where and how you install the belleville disc springs?
    Please post or email a little picture if possible also.
    Thanks Alot,
    Jeff Alessi
    Here's a closeup pic of the bellevilles installed.
    They stack like this ()() if looking at it sideways.
    Hoss
    Feb 2007
    4553
    Daniel,
    What do you set the torque on the bellevilles?
    Thank You
    Jeff Alessi
    I just tighten the drawbar with a toolholder in the collet.
    Then back off the drawbar a little at a time till it just releases the tool
    when the power drawbar is activated.
    Want it to grab as tight as possible but release and drop the tool when activated.
    Hoss
    Sep 2006
    1738
    Drawbars are sweet! Especially when there pneumatically controlled! Damn!
    -Jason
    X2 Basher be damned, I do like mods.
    The power drawbar is one of my favorites.
    It isn't necessary for adequate function, but makes life easier and isn't that the point!
    Even without an ATC I'd want a Power Drawbar now that I've used it.
    You can setup a SATC(semi-automatic tool changer) with one.
    Just line up the tools you need for a job and when the program calls for a tool change,
    it's just pssh, pssh by hand and you're ready to go.
    Harrisson machining is coming out with a cool simple power drawbar design soon (bottom of the page).
    I do like things simple.
    Hoss
    Jul 2004
    218
    Wowsers Penney!
    A 16 tool changer'll beat the tar outta that $1500 changer on LMS. It must be scary to live on the cutting edge.
    May 2005
    101
    Quote Originally Posted by hoss2006 View Post
    Hoss
    I don't get it. How is Harrisson's power drawbar simpler than yours?
    Same principle. Maybe simpler bracketing, but not by much!
    tom
    Hey Tom,
    I like the lack of the side plates like mine but the air cylinder in front is a little obtrusive though.
    Working on a screen set for Mach 3 to go along with the 16T ATC.
    Using Screen 4 to modify the old 1024.set. Pretty simple to use once you get into it.
    There's a video tutorial here.
    Want to have the functions I use most on the main page instead of jumping back and forth.
    I have lots of extra buttons I can assign on the new mill console.
    Hey Dang,
    Maybe I should get in cahoots with LMS like Ron Steele did.
    I think I've proven that the X2 is a formidable little mill that can be pushed beyond
    factory recommendations and untap it's potential.
    The cast iron construction and R8 spindle give it a great foundation to explore the possibilities.
    I used it for 2 years straight out of the crate with amazing accuracy for the money.
    (I'm used to running Bridgeports at work)
    Then I got the mod bug and the rest is history.
    Once you go CNC, can you go back?
    Hoss
    Jan 2007
    12
    Any updates on this project?
    Hey wombat,
    I have all the prints finished, received the stock and bearings and made the programs to cut the
    complex parts with CNC.
    Just have to order a stepper yet and cut the parts when the mill is running.
    Shouldn't be too much longer, maybe.
    Hoss
    Jul 2006
    122
    This should be gooooood !!!!
    Progress is being made again now that the mill is running again.:banana:
    Think I used too much of the stock I bought for it on a rash of Stock kit sales along with DVD-ROMS. :cheers:
    Must have been the stimulus checks.
    I'll have to take inventory just to be sure I have everything so that I could crank
    out all the pieces over a weekend.
    I'll get around to making a tutorial for the programs I use to go from CAD drawing
    to Gcode too.
    Hoss
    P.S. I'll keep a log of the progress here too, a lot easier than constantly updating my webpage.
    Membership is free but not necessary to view.
    Back to work.
    Have all the programs made to cut the parts.
    Ran into a little snag milling some pockets for the bearings that were not coming out perfectly round.
    Checked and found the mill developed some backlash, might be time to replace the ballscrew mount bearings.
    Till then I searched and figured out how to get the backlash comp working properly in Mach 3.
    Works awesome,:cheers: Art!
    Good thing since this is one of the parts I have to make, backlash slop would have ruined it.
    Hoss
    Made a tutorial video to show the before and after.
    [ame="http://www.youtube.com/watch?v=A27nOkTFYDY"]Mach 3 Backlash Compensation[/ame]
    Jan 2007
    12
    What is that last thumbnail drawing of? I am still very interested to see how you do the carousel.
    Any chance you well sell kits for this ATC when you are done?
    Aug 2006
    1602
    Quote Originally Posted by wombat View Post
    Isn't that thumbnail a portion of a tool carousel for differently sized tool holders?
    Quote Originally Posted by digits View Post
    Give that man a cookie
    Will surely sell a DVD-ROM and probably some of the large parts such as the wedge
    which is 12 inches long.
    Got off my butt and made one this evening.
    Hoss
    BOM
    Hoss, how about a bill of materials so we can get started acquiring the parts
    ans materials ahead of build.
    Paul K.
    Aug 2006
    1602
    Chocolate chip please
    If that segment's anything to go by, that's going to be a pretty impressively sized tool changer! Are you going to have springy fingers to keep the tools in place, or are you just relying on gravity and the shape of the cut-outs?
    Keep up the good work!
Page 1 of 16 12311
  1. Automatic Tool Changer
    By Rockwall in forum Tormach Personal CNC Mill
    Last Post: 04-21-2008, 11:34 PM
  2. I wish I had an Automatic Tool Changer...
    By Chris64 in forum Uncategorised MetalWorking Machines
    Last Post: 09-10-2007, 01:59 AM
  3. Automatic Tool Changer
    By spalm in forum DIY CNC Router Table Machines
    Last Post: 07-11-2007, 01:49 AM
  4. Automatic Tool Changer
    By Chivo in forum Mechanical Calculations/Engineering Design
    Last Post: 03-20-2007, 12:57 AM
  5. Automatic tool changer
    By bunalmis in forum Mechanical Calculations/Engineering Design
    Last Post: 02-04-2006, 10:57 PM
