586,105 active members*
3,210 visitors online*
    Apr 2006
    266
    110V power in
    For my control box I have one 110V line in. I was wondering if that one line with a 20A circuit would be enough power to turn on the control box, spindle, and coolant? I didn't know if that would be to much for on circuit to handle. Also what is the common gage of wire for a usb cord to supply 5V@500ma? I was going to use 22g.
    Jan 2004
    105
    Quote Originally Posted by krymis View Post
    How big is the spindle?
    Monte
    Apr 2006
    266
    it is for an X2 minmill. It has a 4/5hp motor on it. I am using the probotix 3 axis kit with a 24V 4.5A power supply. I also am using the cnc4pc c11 REL1.1 board. It has a usb cord to it along with a 5v@2a and 12v@1a power supply. The last part of the equation is the coolant pump is from grizzly. It is the 3 gal kit that they sell.
    Jan 2006
    738
    You should be fine with the single circuit. One thing you can do is to convert all your voltage and current ratings to watts. Volts X Amps = Watts, then add up to get total wattage and divide by 110 to get total Amps. Your spindle of 4/5 HP will not draw more current than the fuse right there under the speed control, probably 5 amp.
    24 V 4.5 A = 108
    5 V 2 A = 10
    12 V 1 A = 12
    4/5 HP (aprox) 600
    coolant pump (a guess) 200
    total wattage 930
    call it 1000 watts for a little overhead so you have about 8.3 amps.
    Sounds like a good setup.
    Have fun
    Steve
    Apr 2006
    266
    great..thank you for checking over that for me.
  1. Using USA 110V Equipment on Euro 220V Mains!
    By diarmaid in forum CNC Machine Related Electronics
    Last Post: 09-07-2021, 11:54 AM
  2. 110v single phase bridgeport motor swap
    By stanglou in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2011, 12:41 AM
  3. Power one Power Supply
    By teamtexas in forum CNC Machine Related Electronics
    Last Post: 10-13-2007, 11:05 PM
  4. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  5. E-stop, Interrupt The 110v Ac Or 28v Dc?
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 02-06-2007, 03:49 PM
