586,076 active members*
3,669 visitors online*
    Apr 2005
    18
    Cool Trunnion Tables
    Hi every one .. I need to know if HASS VM-3 can work as 5-axis with the use of Trunnion Tables (TR1605XB , TR2105XB , TR3105XB )
    or the previous Trunnion Tables can only work on the
    5-Axis - Trunnion (i.e Vf-2TR , VF-5/50TR etc ,,, )
    Need you help
    :drowning:
    Hussam
    Nov 2007
    1702
    A VM-3 is just a VF-3 with different slots on the table and slower pitch ballscrews. The trunnion machines are just VF models that come factory equipped with the trunnion installed.
    So yes: if you have a VM-3, all you need is to get the 5-axis option (two more amplifiers and some cabling) and the two-axis rotary or trunion table of your choice.
    Greg
    Mar 2008
    5
    Brush vs. brushless for rotary tables
    If I understand correctly, you need to be sure you match the components (axis drives) to the tables as far as brush vs. brushless drive, probably not a challenge if you're buying new, but might be something to watch out for if you're looking at previously owned, which I guess you might be, as I've heard that the backlog for some of the rotary stuff from Haas is on the order of 6-8, or even 12-16 weeks for some models?
    Apr 2005
    18
    Donkey Hotey, usjess :
    thank you for the reply , I am sure now it is possible to have trinnioun table on VM-3
    actually we are looking to buy USED CNC machine .
    I am living in JORDAN (AMMAN) any help or any supplier are welcome .
  1. T-Slot tables
    By coolman in forum DIY CNC Router Table Machines
    Last Post: 05-26-2006, 07:30 PM
  2. Trunnion Table for 5-axis
    By Zumba in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2006, 04:09 PM
  3. Tool Tables
    By mmorton9 in forum Mach Mill
    Last Post: 01-17-2006, 11:01 AM
  4. Tool Tables
    By mmorton9 in forum Mach Software (ArtSoft software)
    Last Post: 01-10-2006, 12:01 AM
  5. What do you think about these tables
    By xairflyer in forum DIY CNC Router Table Machines
    Last Post: 09-09-2005, 01:23 PM
