It's possible that I may have in time what I think could be the nicest Enclosure for a Taig CNC. At least for me lol. So you guys have probably seen my half built enclosure, black mortar tub with flood cooling. I was going too build a 8020 quick-frame design around it. Eh, but that may change, it just may change.
I go too school at New Jersey Institute of Technology as an MET and being the technical guy I am, I have this thing about "perfection" and symmetry relating too how parts work, how they are designed and put together etc. Well my school has some great things that are thrown out and I always pass by them and wonder the things I could do with them. For example, I saw this console station yesterday that had some screen in it, probably used in the electronics department and it could be cleaned up and used for A Mill Console, it was awesome! But anyway, I was passing my lecture hall and for the past 2 months, these Steel, white cabinets have been sitting outside the classroom with some junk Steel (heavy duty) open slot tubes; like so [ . I had the chance too look at it and starting getting ideas. I was thinking what a great enclosure this could be! I was excited.It has two nice thick doors with handles on top and is completely made of stainless steel. The cabinet measure I would say around: 35 inches in height, 50 + inches in width and 25-27 inches deep. I would have no problem with X axis travel and the Y axis should fit just fine.
Before I get to the "drainage"/mounting Mill problem, some more things too talk about. The Back of the cabinets has two openings, around 6 inches wide and 14 inches in height. I would cover these with plexiglass and even though it's in the corner, it would still be awesome, cause I have spare plexiglass. On the side of the cabinet, I would like a window so I can see when I'm running it from my desk, I would now cut out a window, file and any edges and mount plexiglass. The Doors are thick, but not one piece, worst case scenario, I make new doors entirely out of plexiglass and mount them with hinges too the cabinet, I still want too make windows in the doors. We'll see.
Now the big question, how will you mount the mill and drain with a flimsy bottom. The cabinet floor is raised about 6 inches form the ground, so if you flip it over, it's a 6 in deep rectangle. My initial idea was too take steel and mount it directly to the back on the inside and on the side of the cabinet, Then i would take more steel and lay down a bed, making a "T" so the Taig could be bolt too the steel and have some rigidity. Again, this was my first idea and I don't know how well it will damper vibrations or cause them
Second Idea: I would on the inside of the cabinet start too form a bottom bowl with a mallet. I would beat the bottom of the cabinet floor from the "top", where the mill would be. I would do this until I got a large enough slant and bowl like affect. I would flip the cabinet over and fill the bottom 6 inches with concrete. The smashed in floor would act as a mold and when the concrete settles, it would shape up too be a bowl. I would... I think, need too seal the concrete and maybe smooth out the bowl. Having the cabinet flipped over now. I would mount two steel beams to lay on the concrete edges that would "gape" over the bowl; they would be mounted too the concrete. I could then design a drain system from there and the coolant, well, gravity would let it fall over the beams into my bowl and drain through filters. Once it is shaped and everything looked good, I would seal the concrete and seal all areas using caulk or some type of sealant.
It's sounds pretty complex but the idea is not so bad. The concrete would make for a great foundation.
-Jason
