586,119 active members*
3,538 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > HITACHI SEIKI 25S/FANUC 10T PROBLEMS
    Feb 2006
    15
    WE HAVE A HITACHI SEIKI HITECH TURN 25S WITH FANUC 10T CONTROL AND WE CANNOT GET THE MACHINE TO MOVE IN ANY AXIS IN THE NEG DIRECTION WHILE IN MANUAL MODE.THE LATHE WILL ZERO RETURN AND WILL MOVE IN A NEG DIRECTION WITH A G0 COMMAND WE HAVE NO ALARMS!I THINK THAT A PARAMETER MAY BE SET WRONG BUT I'M NOT SURE WHICH ONE.ANY IDEAS?
    -SHAWN
    Sep 2007
    371
    Have you checked the jog feedrate switch position????? Or maybe this switch is bad.
    GP.
    Sep 2007
    371
    Sorry, your jog feedrate switch must be ok if it moves to the positive direction. If the problem is in the parameters you must check the stroke limit param. These parameters are no. 5220 to 5225.
    Good Luck.
    GP.
    Feb 2006
    15
    GP,
    Thanks, we found our problem, it was a faulty tool presetter not allowing us to move in a negative direction.
    --shawn
  1. Hitachi Seiki 4NE 600 parameter fanuc 3T-D
    By ahmedrehan in forum Fanuc
    Last Post: 11-06-2010, 10:49 PM
  2. Fanuc 6MB Problem on a Hitachi Seiki VA-50
    By bachlewelding in forum Fanuc
    Last Post: 05-04-2008, 12:21 PM
  3. Hitachi Seiki HT 20
    By besc in forum Uncategorised MetalWorking Machines
    Last Post: 03-31-2008, 03:19 PM
  4. Hitachi Seiki
    By mroy0404 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-08-2007, 05:28 AM
  5. Hitachi Seiki
    By cre8tunes in forum Community Club House
    Last Post: 11-18-2006, 02:40 AM
