586,103 active members*
3,304 visitors online*
Results 1 to 7 of 7
    Oct 2007
    6
    Kevlar for acme nuts?
    Hello to all, This is my first post, but have been running around here for quite some time. I just acquired a bit of Kevlar rod and was wondering if anyone has used it for acme nuts. My machine is a moveing gantry type of router (3 axis) that I also do light aluminum with. Any thoughts or comments ?
    Dec 2007
    617
    Hi: What would be the perceived advantage(s) of using kevlar?
    regards
    Can't Fix Stupid
    Jul 2006
    1256
    Kevlar is resistant to cutting.Tapping it would leave "fuzz"
    If you cut a kevlar composite there is always fibers sticking out.Great for secondary bonding,not so great for a nut.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Oct 2007
    6
    Thanks for the reply's!
    cam1, the reason is, right now all of the nuts on my machine are made out of teflon, Teflon is too plyable, almost like clay. I have built my machine useing just what I have laying around for the most part. I've had a lot of fun building this this way, but have learned some hard lessons also. the nut on my x axis keeps failing, and just happened upon some kevlar.
    igalla, you are right, I cut a couple nuts tonight. Kevlar machines real nice on the lathe, but hard to tap, kinda tears, ugly threads (home made tap). put the nut on anyway ( wear comp. nut). It works ok for now, but not promisising. I guess I'll have to spend the money and but a real tap and mabe go with brass for a nut??
    Dec 2007
    617
    Tip: Try an oillite bearing (oil impregnated bronze). You can get tham from bearing shops.
    You may even find one that's already got close to the OD/ID combination you require.
    Built in lubrication....
    regards
    Can't Fix Stupid
    Oct 2007
    6
    Duh.. what a great idea. I have a couple of bars on hand.. just got to pop for the tap. Thanks, I like it. ( but it might have been bullet proof with the kevlar ) :-)
    Dec 2007
    617
    For every solution there is a problem...
    regards
    Can't Fix Stupid
  1. 3/8-10 2 start Acme hex nuts
    By Paul R in forum Want To Buy...Need help!
    Last Post: 03-28-2008, 01:25 AM
  2. ball nuts for acme screws?
    By grahamshere in forum DIY CNC Router Table Machines
    Last Post: 01-09-2008, 05:03 AM
  3. ACME thread and derlin nuts
    By SatanKlawz in forum Linear and Rotary Motion
    Last Post: 05-16-2006, 04:13 AM
  4. Idea for Zero Backlash Acme nuts
    By widgitmaster in forum Linear and Rotary Motion
    Last Post: 01-16-2006, 04:11 AM
  5. i need some acme nuts
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 01-27-2004, 07:33 PM
