If you wanted a metal table, you could perhaps construct one out of aluminum plate and bar. My idea is first get a piece of 1/2" aluminum plate sawn out for the base size. Then, build your own T-slot system by sandwiching bar stock on top of this base. For example use a 1/2 x 2" risers with a 1/2 x 3" header on top. The header overhangs the riser to create the T slot.
The basic mode of construction would be drilling and tapping a bunch of holes through this. If you do this from below, then you could hide the evidence of construction A skim cut would clean up the top.
Perhaps in this day and age of magic epoxy compounds, you could use more epoxy and fewer screws to join it all together in a rigid mass.
If you bypass the welding, you'll make decent use of the stock flatness of the material, which is often not all that bad.
