586,072 active members*
4,652 visitors online*
Thread: HURCO BMC 40
    Feb 2008
    10
    HURCO BMC 40
    We are having trouble with our Hurco Mill. When we power up and try to reference the axis, the machine will reference the Z and Y axis but then throws up an error on the X axis Encoder fault. I swapped the encoder with the Z and Y
    encoders and it still threw up the error I have also had the X Axis cables replaced that didnt work. Hurco Tech Support has been awful now I'm stuck the only other thing I can add is on the X axis circuit board there is a little led window that shows the number 1 code I'm not sure what this means.
    Any help would be greatly appreciated
    Andy
    Mar 2008
    25
    what type of control do you have- if it's fanuc, could be a parameter. i've had this issue before and thats all it was.
    Feb 2008
    10
    it's an ultimax control
    Mar 2008
    25
    Sorry, don't know this control, but it could be same issue, there's a parameter which might need tweeked, i would ask your ultimax guy, could save you alot of grief!
    Apr 2008
    6
    It sounds like a mechanical problem. Check the bearings on the ballscrew. On our old bmc 20 coolant gets in and causes problems.
  1. looking into getting a hurco
    By dniemela in forum HURCO
    Last Post: 01-30-2009, 09:33 PM
  2. hurco vm1
    By copperhead4321 in forum CNC Machining Centers
    Last Post: 12-01-2007, 07:05 PM
  3. Hurco ?
    By GLUE1 in forum HURCO
    Last Post: 08-30-2007, 02:31 AM
  4. Hurco VM1
    By Steve@Reliance in forum HURCO
    Last Post: 03-05-2007, 10:32 PM
