Originally Posted by
Dan Fritz
Hint: If the Fanuc does not see a "high" signal on it's pin 5 (CTS, or Clear to Send), then it can not sent data. That's the only way that I know that you can make a Fanuc just sit there blinking "EDIT" without sending any data. Connecting pin 5 on the Fanuc to the RTS signal on the PC will work (as shown above), but also you can jumper pins 4 & 5 together on the Fanuc side. The problem with the jumper is that the Fanuc will then send the program whether or not the PC is ready to receive. Most DNC software will turn on RTS (pin 7 on a 9-pin plug) when the COM port is opened and turn it off when the port is closed.
If the Fanuc blinks "EDIT" forever, then your culprit is a missing signal on pin 5 of the Fanuc. If the Fanuc blinks "EDIT" for a while and then turns off, then the Fanuc is really sending data and you're just not getting it. In that case, check the connection from pin 2 on the Fanuc to pin 2 on the 9-pin plug. Thats the transmit data pin (from the Fanuc to the PC)
The Xon/Xoff handshake is a frequent problem with Fanucs. Many DNC programs can not respond to an Xoff handshake signal fast enough for a Fanuc. This results in an "087 BUFFER OVERFLOW" alarm. This subject has been discussed many times on this forum, and a search for threads with this subject will yield a ton of past responses from members.
