586,096 active members*
3,683 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Apr 2008
    55
    Haas SL-10 not holding size.
    First I would like to say hello to the Community!
    I have been lurking for a little and Registered to this informative site.
    Now for my problem........................
    I have a SL-10 lathe which is 1year old.
    It has never been stuffed so far, but is exibiting this problem drifting in "x" axis. We warm up the machine and it will cut a specific size and then after a couple parts it will jump as much as .003 all at once to a smaller in size. If I move the offset to compensate for that .003 all is good. As more run time goes by with more running of parts it starts to show big by .0005-.0008. I make the change in the offset again following it as it needs to be reduced every couple pcs, then it ends up at original startup offset dimension and is right there, and stays there. Once it "jumps" and gets it out of its system, and it settles in after it will hold tenths all day long! I am totally baffled as to what is going on here and have run another Hass Sl-10 in the past and it didn't show this type of problem. We also spoke to the Haas Tech(A really Sharp Guy) and he could not find anything or think of anything other than Screw thermal comp settings, but they are blank. This is also not a material related issue, because it has been going on for a while with all types of material.
    Other than this particular problem this Haas lathe is a decent machine.
    Any help chasing this Demon out would be very much appreciated.
    Paul
    Nov 2007
    1702
    Quote Originally Posted by Mr.Xtreme View Post
    ...he could not find anything or think of anything other than Screw thermal comp settings, but they are blank.
    I don't have an SL10 but I don't think those values are supposed to be blank. Do you have the original parameters list that came with your machine (in the back of the factory-supplied manual)? The values should be in there. Or you can call the factory. They should have the records of exactly what was (and is supposed to be) loaded on there.
    I wonder if there are some inter-related parameters that affect the thermal comp settings as well. Since it's holding value after a good warmup, I'd say some tweaking must be in order.
    There--that should hold you until somebody more knowledgeable about the SL10 comes along.
    Greg
    Dec 2007
    19
    Hi Paul,
    There is a thread on the Practical Machinist website that sounds similar to the problem you are having.
    http://www.practicalmachinist.com/vb...d.php?t=150372
    Jan 2008
    136
    if it has thermal compensation, try turning it off. the machine should then gradually "grow" from cold, but in a logical way. when the machine achieves optimal temperature the workpiece sizes will stabilize. if this happens after turning off the comp, then it points to a comp sensor or regulator card error. try running the machine in a warm up program to see if you can stabilize things sooner.
    Apr 2008
    55
    How do you turn this off?
    The thing that is puzzling me is that it might be fine 1st pc and then 2nd, 3rd pc than all at once it will move smaller by .003 all at once!
    Geez, I wouldn't be so upset about it, but I'd rather it went to the big side error.
    Warmup is always better to stabilize machine tool, but even after doing that for a 30 min warmup of the slide and spindle with the "z" offset brought back and running same part program for making pc it moved during the first pc.
    There was 3 different sized journals on this part and the first two were right on the size and then the last one cut with same tool during the same cycle it cut small by .002
    Paul
    Feb 2007
    381
    It must be something with the SL-10. Although we love ours, it has a similar problem. We do not warm up the machine in the morning, though. I notice that it will run the first part or two right on size. Then it shrinks for roughly 30 to 45 minutes, sometimes as you stated up to 0.003". Then it will start to warm up and grow. Generally speaking, depending on the part we are running, it will take between 3 and 4 hours for it to completely stabilize. At which time, it will hold +/-0.0001 the rest of the day, provided the insert doesn't wear out.
    As for the thermal comp, ours came set from the factory with no numbers entered. If I want it set, I will have to figure it out. For now, I think it is easier to just monitor it since we normally check parts regularly anyway.
    Good luck!
    Gizmo
    Jan 2008
    136
    Lightbulb
    There is no mystery if the thermal compensation hardware is defective, it will cause the axis to jump around. Usually, the comp moves the axis in a plus direction because the machine is "growing" and will cut deeper as a result. For example for every 1 degree temp increase there may be 0.0001" in compensation.
    There is usually 2 sensors (sometimes 3) on a machine and the the electronics monitors them both for temperature changes. The software then does the math for compensating axis or spindle growth. It could be just one of the sensors is at fault or the control card for them, or maybe even a loose connection. But you will need to investigate further, that is why I said before to turn it off if you can to progress the diagnosis.
    Apr 2008
    55
    How do you turn off the thermal compensation circuit?
    Don't want to sound like a dummy, but the table have no user data there and I can not find anywhere else related to the turn-off.
    Apr 2008
    55
    Thermal comp sensor is set to "False" now.
    We shall see what happens over the next couple of days.
    So far a .0016 total comp was changed on the offsets afterwards instead of the usuall .003 or so. It also didn't seem to jump "All at once" as it did when the circuit was on.
    At this point, I would leave it off and just follow it as it warms up, having no surprises. This is manageable
    Thanks Guy's! All the posts here got the wheels turning to get this problem taken care of.
    I will post back in a week or so and confirm or not if this truely was the problem.
    Paul
    Dec 2007
    617
    Hi:
    I had alot of problems with the X axis on a CNC lathe (Not a Haas).The machine would not repeat on X, or drifted as the day progressed. Turns out it had nothing to do with the thermal expansion.It was a stiffness/levelling issue.
    Someone will probably argue that the castings are stiff, etc. as I did when we tried to solve the problem.
    If you are a skeptic, mount a dial indicator on the crossslide, and indicate on a piece of stock. Have someone turn one of the jack scews near the headstock (+/- 1/2 turn), if you see a change in the indicator, consider fixing the machine to the floor (provided it's concrete).
    Here's what we did:
    1. Levelled the machine (spirit levels on both axis).Took a long time!
    2. Bolted it to the floor.
    3. Re-checked the levelling.
    Since then (3years ago) it's been able to hold dimensions without a problem.
    regards
    Can't Fix Stupid
    Apr 2008
    55
    Smile
    Cam1
    Yeah, I hear you. Ours is on an 8" thick one pc., not sharing another section of flooring. Although it is very level, still, it is not bolted. I believe that truely is the best thing you could do.
    When the riggers brought the SL-10 in they used a hand pallet jack. The VF-2 Super was another story coming thru an 8' door!!!!!
    We had set a pc of stock in spindle of SL-10 after the turn off of thermal sensor, and a tenth indicator and checked repeatability and it is right there.
    I am a happy Camper
    Dec 2007
    617
    Hey: Just one more comment:
    With no cutting forces presesnt, I'd expect the indicator to repeat, with cutting forces present you could have deflection & distortion, resulting in an inaccurate cut. It's a bit of the chicken and the egg thing. The company we purchased the machine from tried to say that we didn't know how to machine....so I invited them to see the problem. If I was the one who was the cause of the problem, I'd pay the bill. 2 days later the rep left frustrated and confused. After that the machine was bolted down and levelled at their expense.
    PS:
    They installed glass scales at no charge in order to try to solve the problem, befor bolting doen the machine. FREEBEE
    regards
    Can't Fix Stupid
    Apr 2008
    55
    Cam1,
    Yes, the Glass Scales for extreme size holding I am to the understanding is the way to go.
    Well, Day one here, and Mission Complete.
    I see the way the Machine is behaving and where the offsets are now and we were Cutting 8 shafts. Some decent material removal, semi finish, final finishing. The Machine did not Jump
    Jan 2008
    136
    Smile
    as a CNC service tec, I see temperature issues every day. my advise to you was based on my experiences..........I am pleased all is well now. (temp.comp is not always best way to proceed, sensors and controllers are not perfect.)
    Feb 2008
    547
    Other things that effect size, growth and repeatability
    Just comments on other things I have noticed that effect size, growth and repeatability:
    Coolant temp - it warms as the run day progresses...there is a lot of energy heat cutting metals.
    Coolant available - Low on coolant... and the pumped flow pressure and volume decrease and so does your ability to remove the heat from the cutting area. Material heats up... your machine cuts to programmed size...material cools back down and your part is undersized. (Especially in alum.)
    Coolant mix – usually not an issue for heat removal…but it can be a tool life issue and effect the cutters ability to cut consistently to size. Clean cutting edge and all that.
    Coolant stream location on the cut zone and the right nozzle.
    How the chip forms as it flows off the part. Is it breaking or a nest.
    And..... the big ones... mechanical and electrical, which was already mostly covered.
    A few years back, I ran about 15000 small Alum. .800 OD and .750 ID motor endcaps with a .375 bearing bore. We were forced to hold plus .0000 minus .0002 on all three of those features because the platers (anodize and a dichromate coating) were using up the rest of the tolerances. We would add .0007 in the morning and first part off was in tolerance and over the first 2 hrs we could slowly and predictably back down that added number. From there… it would hold all day with a fall out of maybe one or two on a 3 and a half minute per part run time.
    I guess my point is that you were right to call the dealer and expect more from your machine. I sent one back (not a Haas) after a year because they couldn’t get it right. So there are some lemons in the best of machines. Keep checking your machine until your happy with what your getting…that is what the warranty is for.
    Every machine has some change as it warms up but I have come to the conclusion that the size change should be repeatable, consistent, and level off at a predictable point.
    I believe growth on a small machine such as yours should not exceed .0007 or .0008 tenths and level off at about the 2nd or 3rd hour. It certainly should not have tolerances bouncing around… and hold .0001 to .00014 tenths, once it is settled in (everything else being equal).
    Good luck. -Steve
    Apr 2008
    55
    Philserveng,
    I will never put that circuit back on again. It appears to be useless, As far as we are concerned it is more trouble that it is worth.
    Thanks again for the heads up. I never expected to straigthen it out so quickly. I guess some times you win one.
    Paul
    Feb 2008
    18
    So How did you turn the thermal comp off?
    I'd like to try my Sl30 with out the thermal comp on.
    Feb 2007
    205
    Thermal comp on SL's
    If you turn off your thermal comp .. there is a paramter 229 that is used in conjunction with thermal parameter ... Call your service tech about what to change it to if you turn off the thermal
    Apr 2008
    55
    To turn it off you must first go into settings and allow to write to parameter.
    Then go into param # 266 "TH SNSR COMP" and set to Zero.
    Very easy, and if you don't like the result, just put it back, but if like me, will never put it back on.
    Paul
    Apr 2008
    55
    Just thought to write in a couple weeks to you all know that the turn off of the Thermal compensation did do the trick.
    No More Surprizes! Machine is nice and stable now and once more a Joy to operate
Page 1 of 2 12
  1. what size 3 phase coverter haas vf-2
    By mls in forum Haas Mills
    Last Post: 04-06-2008, 02:01 AM
  2. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum LinuxCNC (formerly EMC2)
    Last Post: 10-05-2007, 10:52 AM
  3. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum Mach Plasma / Laser
    Last Post: 10-04-2007, 02:49 PM
  4. X3 base size or minium bench size
    By kenrc in forum Benchtop Machines
    Last Post: 02-04-2007, 01:50 PM
  5. Ballscrew size -vs- project size
    By Alan T. in forum CNC Machining Centers
    Last Post: 10-19-2004, 02:53 AM
