586,082 active members*
3,772 visitors online*
Thread: keyboard,,
    Apr 2008
    Question keyboard,,
    hi all,,, new too this forum,, so have some patience,,,thanks,,,
    having a problem with my vf-7 ,,, sometimes the keypad works ,and sometimes it doesnt,, I boot up the machine and press the keypad,
    and there is no response ,, i have taken off the panel in the back ,,
    and made sure everthing is tight, the ground wire for the pendent was loose ,,, and i silcon one of the socket fitting ,to keep from coming apart
    any help ,,,,thanks
    Bill
    Apr 2008
    65
    do any of the keys work? What year machine? Any damage to the keypad?
    Apr 2008
    keypad on vf7
    no keys work at this time ,,, machine is a 2000 and ,,no damage to the
    keypad has happened,,, i take very good care of this machine ,,
    the keypad was working intermittently ,,then just stop all together ,,,
    sole propietior,,, and bad speller
    Apr 2008
    65
    There is several things that it could be, unfortately. First i would try a new keyboard, then there is what is called a SKBIF, (what the keypad plugs into inside of the control pendant). After that you can check the "850" cable back to the Processor board, should be the last board in the stack of boards inside the control cabinet.
    Most of the time its a keypad, more recently i've seen the SKBIF go bad as well, and last but not least (and more expensive) the processor board.
    If the Processor went bad, it usually means that you just lost all your programs and par/sets. So hopefully it will work once again, to where you can save those before it (if its the problem) goes out completely.
    All this info, im assuming that you have a brushless mill, if you have a brush mill some things will be different.
    Hope this helps
  1. The keyboard doesn't work
    By TU ANH DUNG in forum Fanuc
    Last Post: 07-23-2007, 06:32 AM
  2. Keyboard problem
    By BeliVolk in forum CNC Machine Related Electronics
    Last Post: 07-10-2007, 07:00 PM
  3. Anyone know where to get a 32MP Keyboard?
    By A+ Machining in forum Fadal
    Last Post: 06-29-2007, 07:18 PM
  4. I need a replacement keyboard Key
    By donl517 in forum Fadal
    Last Post: 06-14-2007, 11:52 AM
  5. keyboard jog
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-09-2004, 03:17 AM
