586,103 active members*
3,121 visitors online*
    Dec 2006
    34
    Surfacing Bits...
    What bit should be used to surface a table once it's built? The spoilboard surface is 3/4 MDF on a 4'x8' table with a Porter Cable 3 1/4hp router. I wasn't sure using a fly cutter in a router was safe or if some other tool should be used/intended for this purpose. I tried to search but didn't find any information on what bits others were using. Thanks.
    If you don't want to spend $300 on a spoilboard surfacing bit, just use the biggest straight bit you can find.
    http://www.vortextool.com/standard/p...fm?groupID=305
  1. Surfacing question
    By frunple in forum BobCad-Cam
    Last Post: 07-12-2009, 02:22 AM
  2. Surfacing
    By SyilAmerica in forum Syil Products
    Last Post: 12-17-2007, 06:38 PM
  3. smooth 3d surfacing?
    By Rich05 in forum Mastercam
    Last Post: 10-23-2007, 04:43 PM
  4. 4 axis surfacing ?!?
    By Janos in forum Mastercam
    Last Post: 08-15-2007, 02:04 PM
  5. surfacing help
    By lt paul in forum Rhino 3D
    Last Post: 07-16-2004, 03:48 PM
