Where can i find a free, cheap or trail software for picture engraving? I am not sure if the is the right term. I am going to buy Mach 3 and I would like a way to take a photo and create a 3d wood carving.
Vectric Photo engrave...www.vectric.com (trial)
thanks...anything cheaper
CAD to Mill DXF Conversion to gcodes for the low price of $25.00.
http://www.cad2gcode.com/id31.html
(I havn't tried this yet, looks good for dxf files)
Free DXF - vectorink.com
I tried cad2gcode before I bought Vectric. cad2gcode was not as good as Vectric was at converting a photo to the vectors that actually drive your machine. Complex photo detail has much better resolution in Vectric also. I think cad2gcode is certainly worth a try to get your feet wet. Ultimately I think you will like Vectric software better when you see the wood creations actually coming off your machine.
http://cnc4free.org/
doesn t get any cheaper than this at 20 bucks for the tutorial and all the software is free , the next best thing to produce as high quality pictures would be artcam at however many thousands of bucks that is ,
i feel the freeware still rides higher quality reliefs than artcam
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
I have the trial version of lazycam but can not figure how to get it to work. I imported a picture and nothing happened. I did not see any helpful info in the help so I thought it did not support it. Does anyone know how to use it?
Lazy Cam does NOT convert photos into a machinable cad file like Vectric does. Belive me Vectric is the way to go if you want to go from a photo to a CNC program fast. Lazy Cam will however create a tool path if you already have a cad format file like a DXF.
“ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
What one man can do another man can do..
BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
Hello David,
PhotoVCarve user and CNC machine builder Stefan Welschoff from CNC-Wood in Germany carved this stunning 3D photograph using PhotoVCarve.
Tony
Thanks for everyone's help.
What program would make it look the most hand carved?
Great looking Photo Carve Tony.
The answer is none of the above really.. the software(whichever it is) will simply interpret the content of the image.. "cut in the style of" is not really in photo-carving software featuresets..
however, if you want a hand-carved look you could try some edits to the image before you process it... distress it a bit.. or texturise it.. using a hand-carved image as the basis for the texturing...
hope this helps
Danny
Look for Profiler6 I've had very good results with it.
Most of the posts of picture I've done, are with profiler.
Jimini
hi
nice job
you use photocarve and mach3 ?
This interests me, as well. I just posted a similar topic...
can vetric do engraving on 3-d surfaces, too? Like on a curved surface?
gmax will create some really cool stuff for engraving , you can wrap a jpeg around a ball or what ever you want ,
http://www.rainnea.com/cnc.htm this software will run within gmax and create code for 3-5 axis , its a pretty cool piece of software , ive played with it some but haven t had a chance to put the code to the machine to see how it performs ,but i have used freemill with gmax as a modeler and was appreciative of the detail that i cut out on my machine , it was outright wicked
one thing i will say is gmax is an extremely powerfull software once a guy gets the hang of it
plus its free , which keeps 500 - 1000 bucks in my pocket
i don't engrave for weak at heart :bat:
