586,457 active members*
3,417 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Yet Another Mini Lathe CNC Conversion
Results 1 to 13 of 13
    Oct 2006
    17
    Just sharing what I have been doing lately, I have a Cummins mini lathe, and a Grizzly Sieg X3 mini mill. I plan to convert both of the to CNC, and decided to start with the mini mill.
    First their was a lot of web surfing to see what other folks did, so this is mostly of compilation of idea, with the X axis conversion being a straight copy of the one rom wrathall.com.
    The X axis will take a 3/8-10 acme lead screw, with a bronze nut. The
    stepper motor is a 166 oz-in holding torque and the timing pulley ratio is
    1:1.5, which would translate to about 380 lbs of thrust. I elongated the
    saddle cutout where the nut travels for a slightly longer travel range.
    The middle set screw that was previously used to adjust the backlash, was replaced by a ball oil hole, with a hole going straight through the bronze nut.
    I also got rid of the compound slide and replaced it with a lock of aluminum.
    The Y axis uses a 5/8"-0.2 ballscrew, with the same pulley ration and stepper, for about 444 lbs of thrust. I got rid of the original apron.
    I have enough room to use the largest (425oz) Nema 23 steppers available, but hopefully I won't need to. I had those 166 oz-in just laying
    around, begging to be used.
    I will be using Gecko 302 drives, I already have 2 of them.
    The Z Axis is done, and things move smoothly by hand. I thought I was done with the X axis, until I found out the acme screw got messed up, and is not perfectly straight, and the lathe is now out of commission until I get some more funds to spend on it and have someone do it (I have another length of acme stock that is straight.).
    Well I guess, I will be focusing on the electronics part (I am an EE) for now, until I get the acme screw done.
    Attached Thumbnails Attached Thumbnails IMGP1425.JPG   IMGP1426.JPG   IMGP1428.JPG   IMGP1429.JPG
    Oct 2006
    17
    More pics:
    Attached Thumbnails Attached Thumbnails IMGP1431.JPG   IMGP1432.JPG   IMGP1433.JPG   IMGP1434.JPG
    May 2006
    573
    Looks great
    Nov 2005
    655
    Looking good....
    Keep it up (the good work),
    Jack
    Walking is highly over-rated
    Oct 2006
    17
    It has been very slow, but there is some progress. I added the limit/home switches for both X and Z, they are all wired to a single CAT5 cable (cut off one end of an RJ45 ethernet cable.)I also installed the slotted optical switch with its disc on the spindle, to do threading, and read the spindle's speed.
    Attached Thumbnails Attached Thumbnails IMGP1467.JPG   IMGP1468.JPG   IMGP1469.JPG   IMGP1470.JPG
    Oct 2006
    17
    Work in progress on the electronics, some pics:
    Attached Thumbnails Attached Thumbnails IMGP1472.JPG   IMGP1473.JPG   IMGP1474.JPG   IMGP1475.JPG
    Jun 2006
    475
    Great thread mate!
    You have done some neat work. I will be following your thread closely incase I ever convert my lathe to CNC.
    Keep up the work and keep posting the pictures.
    Chich.
    Apr 2005
    1778
    It looks like you're using the CandCNC MiniIO BOB. I have a couple of them and am well pleased.
    Alan
    Oct 2006
    17
    Thanks for the feedback Gentlemen.
    Acondit: Glad to hear that you are happy with the CandCNC boards, I have not fired up my board yet.
    I am getting there, I will post more pics as (slow) progress is made, and hopefully the last post will be a video of the lathe in action.
    Chafik
    Apr 2007
    45
    I noticed here and in other forums that replacing the leadscrew along the lenngth of the bed can be done successfully. However, questions about replacing the crossslide's leadscew with ballscrews seem to go unansewred or end with an statement that a suitable ballnut is hard to find. I am sure that there is information out there, in this or other forums but I may be looking in the wrong places or use the wrong search criteria. If this question has been answered previously, can anyone direct me to the source, or oherwise, provide some guidance? Please note that I have not named the axes because the first topic above was confusing to me as to whicch was the y-axis,
    my apologies,
    Wilfred
    Nov 2005
    655
    On the smaller lathes there is a clearance problem under the cross slide (x-axis). The ballscrew nut for a 5/8" ballscrew is 1.00" (square or round) plus the room that the ball return tube takes up.
    There are smaller ballscrews..... but the cost for those are out of most peoples' budget... some of the smaller ballscrews still use a 1" nut (OD).
    Some of the work-arounds for this is:
    Mounting the screw on the side of the cross slide (hard to keep chips off of, lose a little travel in the z-axis, tailstock can't get as close to the workpiece )
    Mount the nut to the front of the cross slide (too many design challenges)
    Use a rotating nut design (loss of travel on x-axis)
    The one I used:
    I mounted the ballnut to the back of the cross slide (ballscrew sticks out the back far enough you have to build a new chip shield for the back of the machine)
    Jack
    P.S. Not sure any of that makes sence
    Apr 2007
    45
    Mini Lathe CNC Conversion Callenges
    Jack,
    You have been very helpful. This is a clear and concise explanation of the challenges posed by that mini lathe and the work arounds that have been used. Maybe some of our members will post pictures of their successful workaround. That could be useful for those of us who do not want to reinvent the wheel. Thanks for taking the time,
    Wilfred
    Nov 2005
    655
    You're welcome Wilfred,
    I have some pictures of the build I'm working on now.... I still have a few things I need to to do to it before I can call it finished.
    I've been lazy lately...... that needs to stop
    Here's a link to the build:
    http://www.cnczone.com/forums/showthread.php?t=54376
    Cheers,
    Jack
  1. 7x10 ballscrew - mini lathe cnc conversion
    By tbilalis in forum Mini Lathe
    Last Post: 03-23-2009, 04:15 AM
  2. TAIG Mini Lathe CNC conversion
    By COROVICD in forum Taig Mills / Lathes
    Last Post: 10-08-2007, 03:14 PM
  3. Sieg C3 mini lathe - My shot at a CNC conversion
    By Guldberg in forum Vertical Mill, Lathe Project Log
    Last Post: 08-29-2007, 08:20 PM
  4. CNC mini-lathe conversion help needed.
    By minilatheman in forum Mini Lathe
    Last Post: 05-24-2005, 01:47 PM
  5. Mini lathe conversion
    By kdoney in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2004, 04:21 AM
