586,103 active members*
3,859 visitors online*
IndustryArena Forum > CAM Software > Mastercam > NOT break arc into lines
Results 1 to 9 of 9
    Dec 2005
    436
    In my G-code arcs are actually made up of many little lines.
    Can I set MCX2 to output arc segments or is that controlled in the postprocessor?
    In the geometry make sure when you analyze the segment it is an arc if it isn't it will not generate an arc unless you use filter or recreate the arc using 3 points is the best way. If it is not your geometry, take a look at the control Def, Arc page.
    Steve Arteman
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Dec 2005
    436
    The Control definition>Arc page has options for breaking circles into 90 and 180 degree arcs, nothing about breaking up arcs into a bazillion lines.
    The help file was not help either.
    your geometry is not an arc then it is a spline go to analyze entitiy properties and make sure it is not an arc. if it is not you will have to recreate it.
    Steve Arteman
    www.cad2cam.net
    www.cad2cam.net
    Apr 2003
    3578
    Quote Originally Posted by Steve Arteman View Post
    Steve Arteman
    www.cad2cam.net
    Here is the Filter Steve is talking about.
    Review picture.
    Cadcam
    Feb 2007
    464
    Quote Originally Posted by cncuser1 View Post
    You can set it by checking a little box.I'll don't remember exactly where it is but I'll check at work tomorrow.
    Stefan Vendin
    Dec 2005
    436
    Quote Originally Posted by Mitsui Seiki View Post
    I'd appreciate it, I tried but couldn't find out how.
    Apr 2003
    3578
    the box is in the picture above. did you check to see if it was a spline or not?
    Cadcam
    Dec 2005
    436
    Quote Originally Posted by cadcam View Post
    I have arcs, nurbbs, and lines.
    But I took a second look at your previous post and the explanation in the help file.
    This is what I was looking for, thanks.
  1. best break out brd to use with smooth stepper brd
    By markus_detroy in forum DIY CNC Router Table Machines
    Last Post: 06-10-2008, 12:14 PM
  2. When do you add a break-out-board
    By dan dimock in forum DIY CNC Router Table Machines
    Last Post: 02-15-2007, 03:11 AM
  3. break out board for 2110MB
    By johnd in forum Servo Drives
    Last Post: 10-17-2005, 03:14 AM
  4. Got a ? on a break out board
    By Ken_Shea in forum CNC Machine Related Electronics
    Last Post: 07-12-2005, 03:44 PM
  5. Bob Campbell Break-out board?
    By A&P Mech in forum CNC Machine Related Electronics
    Last Post: 10-08-2004, 12:53 AM
