586,082 active members*
3,826 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > TM-1P chips plug drain too fast
    Dec 2004
    55
    When IO rough a large part Ifind that I am spending all my time clear ing chips from the drain. Is there any answer other than a conveyor?
    Leroy
    May 2006
    183
    This happens to everyone, apparently even with the auger.
    If you have the auger (which it sounds like you don't), US Shop Tools sells a device that sweeps the chips off the drain.
    My VF-1 has a fitting on the side of the enclosure nearest to the drain. We rigged a line up from the coolant distribution block to this fitting, and then put a tee on it, with 3 loc-line nozzles coming off of it. point them across the top of the drain, and you can keep it clear enough of chips to not turn your enclosure into a total swimming pool. Doesn't work very well, but usually well enough to keep from having to stop mid program.
    My biggest (and really only) regret is not paying the extra $1800 for the chip auger. It's such a PITA shoveling chips out of the machine.
    Aug 2007
    96
    I bought the Device for our Auger that you talk about from US Shop Tools and it was worth the $180.00 we no longer have the drain getting blocked. If you look through the posts I even have a link to a video of it working that I found.
  1. Drain Pre-screen
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 03-14-2008, 05:37 AM
  2. Replies: 4
    Last Post: 03-11-2008, 07:43 PM
  3. SL-10 Coolant Drain Upgrade
    By Edster in forum Haas Lathes
    Last Post: 01-20-2008, 05:01 PM
  4. How hot should LM chips get?
    By phantomcow2 in forum Hobbycnc (Products)
    Last Post: 11-10-2005, 06:28 PM
  5. Cook your chips to make more chips :)
    By ToMMY2ooo in forum Bending, Forging, Extrusion...
    Last Post: 09-07-2004, 07:38 PM
