586,058 active members*
4,613 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > DynaCNC > Need help with Dyna4000 THC control
    May 2007
    111
    I am trying to work around an issue in a Dynacnc Dyna4000 control box. I am looking for some generic information and any insights anybody might have.
    Now if anybody has had this problem and gotten it fixed, I would accept specific help!
    Anyways this control box reports back about a third of the voltage
    that is actually coming in via the tip volts line. (I put a meter on
    tip volt wires while it while running.) So the z axis keeps rising trying to chase the voltage.
    The plasma cutter I have puts out raw tip volts.
    The control box has a selection for raw volts or divided tip volts.
    I have tried putting a low target voltage in trying to fool it, and I
    actually hit my target volts with my meter for a second but then the z
    axis dove into the metal. So that didnt work out.
    So what is the dividing ratio that other plasma torchs use that dont
    give out raw tip volts? I am asking because I am going to try to make
    a tip voltage divider for my plasma cutter and change the control box
    setting over to the divided volts setting and see if that helps.
    Can anybody offer any suggestions. The box works fine without the THC
    on thick plate, but I need to work with thin plate with THC also.
    For those who suggest going back to the manufacturer..
    I tried, they denied, said change things that I have said on internet
    about table and then they would help. But that is not happening.
    Thanks to anybody who can help.
    Feb 2006
    24
    Quote Originally Posted by lowpull View Post
    axis dove into the metal. So that didnt work out..
    So please inform me in detail how you put a low target voltage "trying to fool it" on the control system? I can't understand your comments and how it affects the control system unless you define your process.
    David Cress
    DynaCNC
    May 2007
    111
    Dynacnc4000 reports 50 tip volts instead of the 141 that my meter is reading. So change target in Mach3 and dyna4000 to 50 and see if it works. But it didnt.
    Feb 2006
    24
    The truth will set you free... and this ain't the truth.
    word Bill...word.
  1. Anyone with Dynacnc Dyna4000 controller
    By lowpull in forum Waterjet General Topics
    Last Post: 05-16-2008, 05:53 PM
  2. Seig x2 Speed Control and c6 Control Board
    By skmetal7 in forum Benchtop Machines
    Last Post: 04-21-2008, 09:17 PM
  3. Replies: 2
    Last Post: 12-28-2007, 04:57 PM
  4. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
  5. BobCADCAM Layer Control / Snap Control
    By jonbanquer in forum BobCad-Cam
    Last Post: 01-21-2006, 10:10 PM
