586,108 active members*
3,100 visitors online*
Results 1 to 6 of 6
    May 2008
    12
    fanuc oi help - dnc ?
    We just put in a new cnc machining center with a fanuc oi control.
    We have hooked it up to a PC and use fanuc dnc to upload and
    download progams to the control via rs232. This program is a very
    basic xmit/recieve. Fanuc is new to me since our last 5 machines
    have been cinci's. We used a program called dcdnc with cinci controls
    that allows the user to search the pc for files, upload and download
    right at the control. With the fanuc dnc, we need to run back and forth
    between the pc and control. Is this control capable of terminal emulation
    and is there a program that can search and xfer files right at the control ?
    Jim
    2932
    Your 0i may have the Embedded Ethernet option. AFAIK, that's the only way to "fetch" programs from the control.
    In lieu of that, you could get something like Predator DNC which uses a "Remote Request" command (short program stored in the 0i memory) which you punch out to have Predator search for and send a program from the server... you only need to edit the program name each time.
    Predator Desktop allows you to set up a Schedule (at the PC) of programs, then when you need the next program, you just do a request from the CNC, and it sends the next one in the queue.
    May 2008
    12
    Thanks for the reply
    The ethernet option was outrageous -- 4K
    I did find a program called easydnc. It is easier to use, however
    I still need to press more buttons than I did with the cinci's
    2932
    Welcome to the world of Fanuc!
    Jan 2008
    19
    Fanucs just don't have any client/server capability built in so can't search a remote disk/server for files.
    You mentioned easyDnc - There is a version of easyDnc which has a remote request capability which will save you running back to the PC each time you want a file.
    www.dncremo.com
    Sep 2005
    767
    If your current software is "PC-DNC", then you can remote request files from a Fanuc through a serial link. I know because I wrote PC-DNC, PC-DNC Editor, and PC-DNC Plus. It can accept a remote request, and it can either download or drip-feed the control.
    If you are using one of our products, contact me by email directly at [email protected] Our product support is free.
  1. GE Fanuc & FANUC proprietary posts
    By cncadmin in forum Fanuc
    Last Post: 01-12-2022, 07:33 PM
  2. FANUC & GE FANUC Repairs
    By RRL in forum News Announcements
    Last Post: 04-17-2011, 05:50 PM
