586,094 active members*
3,952 visitors online*
Results 1 to 7 of 7
    Mar 2008
    375
    tuning motors
    once you set up and tune your motors to mach 3 .if you unpluge them from the motor side would you have to tune them back again when pluging them back together.
    Dec 2006
    7
    no because your settings are stored on your computer
    Sep 2006
    881
    i agree that the settings are stored in the computer, but thats assuming that you plug them back in the way that you had them, if you cross one set of the wires you will see a difference(i believe it will reverse direction if your using a bipolar motor)
    Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
    Dec 2006
    21
    Unplugging Motors
    Never unplug the motors while the unit is still on. This will cause a huge back EMF. The spike will damage the drive transistors.
    The tuning should remain the same as long as your using the same kind of motors.
    Mar 2008
    375
    which stepper to which motor
    hello again here is my set up basically I am ready to start running my mill I dont know much of electronics but here is my question does some one have a board like this one i have and also since I am ready to start setting up my motors does it mater which motor I wire to the control or can i just wire any controller to what ever motor. and then ones there wire woulg just set them up. is that the way it works.
    Dec 2006
    7
    i have used then boards in the past /it does'nt matter which motor you conect to each drive ,make sure you know the x/y/z then just config the right wires step/dir in your software /good look
    Dec 2006
    7
    make sure them transistors ain't touching too /was running mine with nema 23 motors worked well /if anything bad not much speed out of the drives before it started missing steps /but worked well at about 15-25 ipm
  1. Question on test/tuning motors ?
    By KEYTEEM in forum Servo Drives
    Last Post: 04-10-2009, 12:27 PM
  2. tuning motors mach3
    By cajuil in forum Machines running Mach Software
    Last Post: 03-25-2008, 10:21 PM
  3. Tuning motors in Mach3
    By tybrenis in forum Mach Software (ArtSoft software)
    Last Post: 05-07-2007, 07:59 PM
  4. Help Tuning Motors on a K3925
    By Dennis Fletcher in forum Gecko Drives
    Last Post: 10-31-2006, 02:32 AM
  5. Anyone got any tips for tuning servo motors?
    By Darc in forum CamSoft Products
    Last Post: 05-08-2006, 06:13 PM
