I am in search of G and M code lists for a Mori SL-403 Lathe. Can anyone assist?
Thanks.
Thanks.
meau.com
The best way to learn is trial error.
I found a copy of an SL-400 Ladder manual for an MSC-501 control. I scanned the M Code list and attached it for your viewing pleasure.
It should be relatively close to the SL-403.
You will need to contact your local Mori distributor for the G code list as I do not have a programing manual for that machine.
RRL
Thanks a buch.
I have a pgm mnl for that machine, but the file is too large.
I have the prog manual for this lathe if you want I can help send this to your address
