Intuitive programming can be retrofitted, it is just software.
Power failure detection can be retrofitted; it is a little module that has to be wired in.
I think High Speed machining is more complicated because it needs extra components on the board; probably will require a whole new board.
You could probably use an external transformer.
BUT...you may run into serious problems with CE. I do not think machines sold in the US meet the full CE requirements. Do a lot of checking on this, you might find the machine cannot be imported into Europe.
