586,121 active members*
3,556 visitors online*
Results 1 to 8 of 8
    Sep 2007
    89
    Unhappy G-Code outside circle Heidenhain
    I have a bridgeport series II interact II heidenhain tnc151a programming g-code in inches I'm trying to make a 2 inch diameter boss .750 deep in aluminum 6061 I 've been able to do it but I had to go and edit the z depth everytime I got the job done but for the next time around I need to know a more efficient way I'll show you how I've been doing it. The center of the boss is the origin. Cutter radius .313
    N10 G00 G90 Y0 X-1.313 z+.1
    n20 G01 z-.1 F100
    N30 G90 I0 J0 G12 H-180 F200
    I let it run go edit the -z and let it run etc...
    Take it easy on me I'm a newbie on programming and this is all I could do to get it to work I wanted to set up a label and have a G91 for the -z so everytime it looped around it would increment down a .100 at a time I had no luck at that says I was missing a tool call
    Apr 2008
    50
    Programming
    I drew out what you were doing and posted it with what I think is a G code Heidenhain post. I never use it in G code. I always use it in plain language programming. With that you could do it in a few lines with a helix. (2nd example). I don't know how you do the helix in G code. I'd have to check. You could do what you are doing with a label also but the helix is easy as long as you have the right end mill and material. It's constant motion in all 3 axis. Hope this helps.
    Kevin
    %UNTITLED G70
    N2 G01 G40 G91 Z0,0 F6000 M91
    N3 G99 T1 L0,0 R0,0
    N4 T1 G17 S2000
    N5 G01 G40 G90 X-5,0 Y5,0 M06
    N6 G01 X1,313 Y0,0 M3
    N7 G01 Z0,1 F6000 M
    N8 G01 Z-0,1 F100
    N9 G90 I0,0 J0,0
    N10 G02 F200
    N11 G01 Z-0,2 F100
    N12 G90 I0,0 J0,0
    N13 G02 F200
    N14 G01 Z-0,3 F100
    N15 G90 I0,0 J0,0
    N16 G02 F200
    N17 G01 Z-0,4 F100
    N18 G90 I0,0 J0,0
    N19 G02 F200
    N20 G01 Z-0,5 F100
    N21 G90 I0,0 J0,0
    N22 G02 F200
    N23 G01 Z-0,6 F100
    N24 G90 I0,0 J0,0
    N25 G02 F200
    N26 G01 Z-0,7 F100
    N27 G90 I0,0 J0,0
    N28 G02 F200
    N29 G01 Z-0,75 F100
    N30 G90 I0,0 J0,0
    N31 G02 F200
    N32 G01 G91 Z0 R0 F6000 M91
    N33 G01 G40 G90 X-5,0 Y5,0 M05
    N34 G01 G40 G90 F6000 M02
    N9999 %UNTITLED G70
    1 BEGIN PGM HELIX INCH
    2 L Z0 R0 F3999 M91
    3 TOOL DEF 1 L0 R0.0
    4 TOOL CALL 1 Z S2000
    5 L X-5.0 Y.0 R0 F3999 M6
    6 L X1.313 Y0.0 R F M3
    7 L R F M
    8 L Z0.1 R F3999 M
    9 L Z0 R F100 M
    10 CC X0.0 Y0.0
    11 CP IPA 2880 IZ-.750 DR- F200 M
    12 L Z0 R0 F3999 M91
    13 L X-5.0 Y0 R F M91
    14 L R F M2
    15 END PGM HELIX INCH
    Sep 2007
    89
    Hey Kevin Wow thanks alot man you took alot of time to help a guy out I'm not at my machine right at this moment but I'll give it a shot thanks again I'll keep you posted on the progress
    Apr 2008
    50
    G Code Helix
    I looked in the ISO programming book (G Code) on how to do a helix and it looks like if you modify what you were using slightly you could do it that way. Try it and see what happens.
    N10 G00 G90 Y0 X-1.313 Z+.1
    N20 G01 Z0 F100
    N30 I0 J0
    N40 G12 G91 H-2880 Z-.75 F200
    The H number is 2880 degrees which is 8 revolutions down .750 so a little less than .100 per rev. I'm not sure of the + or- on the H. I think that will control the direction it spirals. Of course you'd want to have another line after with a G90 G00 to bring Z back up. I did try what I gave you before for the conversational program modified for a TNC430 control and it did work fine.
    Kevin
    Sep 2007
    89
    Kevin thanks that was the ticket worked great much more efficient thanks for your time on figuring that out for me
    May 2008
    5
    Helical interpolation
    Just a question, why are you programming in the ISO format. Heidenhein is a superb language & i have been working with it for 18 years now (from basic work to 3D forms) i have also had alot of dealings with fanuc & acramatic 2100 & I will say that hands down heidenhein will blow the others away by far for ease of use + flexibility. I can give you a solution in heidenhain which would use parameter programming (it's sounds fancy but it works well & easy to understand) or if you like you could use incremental moves & a lable repeat if that would be better.
    Troy.
    [email protected]
    Jun 2008
    4
    Hi I,m with Troy on this Heidehan far simpler language,using variables and label repeats far easier regards G
    Sep 2007
    89
    I guess I just wanted to know what seems to be the universal language first g-code. It has been going well and actually it was worth it because unfortunately one of the cnc programmers at my 9-5 job had a stroke and I was able to have a easy transition to take his jobs over since he programs in g-code that way they didn't have to hire someone to take his position while he recovers and will have a job when he comes back.
  1. Heidenhain g-code help
    By arkum in forum G-Code Programing
    Last Post: 08-29-2017, 04:55 PM
  2. Heidenhain G-code or conversational?
    By bigtoad170 in forum Bridgeport / Hardinge Mills
    Last Post: 04-12-2008, 09:13 PM
  3. Heidenhain conversational code
    By a2p4me in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-26-2008, 11:16 PM
  4. Heidenhain (or anything else!) nc code spec
    By kefex in forum G-Code Programing
    Last Post: 07-02-2007, 06:42 AM
  5. Soweebee looking for helical code for heidenhain tnc351
    By soweebee in forum MetalWork Discussion
    Last Post: 06-09-2006, 06:50 PM
