Hello!
I just wanted to check if there was anybody from Norway here.
We could cooperate in builds and finding resources close to home.
Regrads
Otto Ødegård
Sandnes
Hello!
Regrads
Otto Ødegård
Sandnes
You are not alone, Greetings from Lillehammer
....and from Frosta, Nord Trøndelag.
Knut A
...and from Moss, Østfold.
If you search the member list there is 135 members from norway.
Regards
Bent
Yes, greetings from Stavanger
Oslo aqui!
Greets from Bartebyen aka Trondheim
Have any of you buildt a CNC machine? Im building a joes 4x4(2x2)hybrid.
Do you have a pro cnc machine?
And what do you use the machine for?
Otto Ø
Sandnes
In progress...
Have built an hobbycnc 4-axis controller and the motors are spinning.
Waiting for Widgitmaster to complete the batch of minis
I'll use the machine for PCB routing++
Henrik
Trondheim
EDIT: Usage..
....og i fra Moelv
I bought the HobbyCNC pro 4-axis with 205oz/in steppers.
It was not difficult to make the board, but the installation in the PacTec enclosure was a bit harder, also I used a 24V/8A switching PSU rather than buying a trafo and using the diode bridge that was supplied with the kit.
Henrik
...and from Fredrikstad
Larvik here
btw are ther any norwegian CNC Boards ??? i did have a look at one where they did discuss CNC routers but their main business was RC pliains ...
if no such forum exsist maybe we coul set one up ??? i have some ideas and i got the skill to set it up and do all the maintenace work ..
...and from Tromsø..
Hei alle nordmenn! Er det greit å skrive på norsk i denne tråder? Jeg har bygget en CNC fres som jeg nå driver å tester ut. Bruker Mach3 og strever med å få kontroll på offset-settingene.
Dette er som å sitte på skolebenken igjen, men opplæringskurven er nok blitt litt flatere med årene...he, he.
Se gjerne på noen videosnutter jeg har lagt ut på YouTube: http://www.youtube.com/lnyje
Kommer nok tilbake med masse spørsmål etterhvert.
Knut A
Flott! Hvilken maskin har du bygget?
