586,111 active members*
3,097 visitors online*
    Oct 2006
    69
    Y Profile in Z
    I built a lathe assembly to fasten to my Soylva machine. I am using Autocad to generate the drawings. If I create a profile in 2d and rotate it on the X so the Y profile is now in Z, the post processors I've tried won't accept it. Can anyone help tell me how to get a Z profile as in (baluster) into Mach3?
    Create the code for X and Y, then use find and replace in a text editor and swap the Y's for Z's.
    Oct 2006
    69
    I had thought of that but wondered if that would allow me to control of the stepdowns, say .05 per pass?
    Oct 2006
    69
    Forget that last statement. Duh.. do the offsets on the Y to equal your stepdowns and then do the find and replace. Got it...thanks.
  1. Profile
    By mrdipen in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-16-2008, 02:47 PM
  2. How to Clamp for the Outside Profile
    By stang5197 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 10-18-2007, 07:16 PM
  3. Help with profile
    By TPPJR in forum OneCNC
    Last Post: 12-28-2005, 06:22 AM
  4. When I profile??
    By cncadmin in forum Uncategorised CAM Discussion
    Last Post: 06-26-2003, 04:39 PM
