I'm having something at least strange, the turret is one position after the control, when the control is on the tool number 1 the turret is on number 2...
is there any parameter, troubleshoot, pray or something else to help me?
If you select a tool by MDI, does it index to the correct tool?
Ozemale6t9 asked a good question. What is the answer?
I am not a maintenance man, so I asked ours about your problem. If it is indexing to the wrong station when you use MDI, then what I gather is first you index the turret so that station on is up. There should be an encoder under a cover on the side of the turret. Turn the encoder until a red light comes on. This shouold fix it.
However, if it doesn't please don't take it out on the messenger!
I have the problem solved...
on the mdi the turret index without problems, but with one tool behind the control..
a guy from england gave me the parameter to chance (1805?) I had do select the tool #1 change the parameter (A) from 1 to 0, and changed back to 1, then I turned off and on again, and the machine was working fine....
thanks for all..
