586,069 active members*
3,946 visitors online*
    Feb 2006
    174
    320 gecko drive
    Can you use a 320 to drive a servo on the lathe spindle to controll speed of spindle.
    Thanks Ed
    Feb 2007
    4553
    Is your lathe equipped with a 90 volt dc motor?
    Ed,
    I am going out on a limb here.
    Most likely your lathe has 110 -120 volt ac motor and if so the Gecko is not going to work.
    Please post the motor size in horsepower, voltage and amperage.
    Then it will be easy to suggest a control solution.
    Jeff...
    Jun 2004
    6618
    It would likely work if you are running a servo motor that is within the gecko's range. The question is will it be fast and strong enough?
    I think it's doable for a small lathe.
    Lee
    Feb 2007
    4553
    I apologize for not completely reading your question.
    Ed,
    Lee is 100 percent correct.
    If you are using a servo motor to drive your spindle, the gecko will work if within its operating parameter.
    Lee's question about horsepower with be the deciding factor.
    Jeff...
    Feb 2006
    174
    What I'm doing is adding it to my cnc mill. It will be used like a lathe. My cutter will be mounted to the side of my router. I hoping I can use the spindle setup in Mach3 to do this. I using a small 3" chuck. I have not purchased a motor yet. But I already have and extra 320. What size motor would be good for this and what gearing should I use.
    Thanks Ed
  1. Possible Gecko Drive?
    By juzwuz in forum Gecko Drives
    Last Post: 03-19-2008, 05:00 PM
  2. Gecko drive problem
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-25-2007, 02:54 PM
  3. Which Gecko Drive
    By Lloyd in forum Gecko Drives
    Last Post: 05-31-2006, 07:35 AM
  4. Can Gecko drive this motor?
    By N4NV in forum Gecko Drives
    Last Post: 02-28-2006, 05:55 AM
